Old 30-09-2004, 06:32 PM   #1 (permalink)
Mobile Freak
reddick's Avatar
Default Yahoo! and Spymac on OUTLOOK
Hi their...
NeOne tell me how can i get all my Yahoo! mails in Outlook Express 6?
I use Opera 4 surfing.Tell me how 2 access my Spymac mails in it?Let me know abt all d SETTINGS 2 b done..!
THX
reddick is offline
Old 30-09-2004, 06:45 PM   #2 (permalink)
for yahoo the settings wud be
Incoming Mail (POP3) Server: pop.mail.yahoo.com
Outgoing Mail (SMTP) Server: smtp.mail.yahoo.com
Account Name/Login Name: Your Yahoo! Mail name (your address without the "@yahoo.com")
make sure u Check the box next to "My Server Requires Authentication"
cya
[digitt] is offline
Old 30-09-2004, 07:14 PM   #3 (permalink)
Certified Nutz
sreevirus's Avatar
for spymac
Incoming (pop) server: mail.spymac.com
Outgoing (smtp) server: mail.spymac.com
read this for how to set up SMTP authorization in outlook.
http://www.spymac.com/support/index.php?postid=46
"Don't take life too seriously. You'll never get out alive!" - Bugs Bunny
sreevirus is offline
Old 30-09-2004, 09:02 PM   #4 (permalink)
tuxfan's Avatar
what [digitt] says won't work unless you pay to yahoo
However, go to http://yahoopops.sourceforge.net and download yahoopops. Follow their instructions and you will be able to get yahoo mails in OE6. In case of confusion, post the problem.
Don't know anything about spymac.
tuxfan is offline
Old 30-09-2004, 10:14 PM   #5 (permalink)
ya yahoo is not for free(POP account)
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 02-10-2004, 10:54 AM   #6 (permalink)
adit_sen's Avatar
dude....u got it all mixed up....yahoo pop is not free...
but if u wanna use it....got to http://yahoopops.sourceforge.net/ and download the software. using that u can use yahoo as a pop based mail in any email client....and sorry, i have'nt heard about spymac...
peace
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 03-10-2004, 04:26 PM   #7 (permalink)
Dear Friend i tried it but it works some times but sometims it doesnot work. how to correct it
shivaranjan.b is offline
Old 04-10-2004, 08:43 PM   #8 (permalink)
tuxfan's Avatar
I think it all depends on other programs that may or may not interfer with it while it is running. For example, if you also have ePrompter running, both try to get hold of localhost
Also check out the FAQ that they may have there.
tuxfan is offline
Old 05-10-2004, 07:02 AM   #9 (permalink)
u need 2 set the time 2 the max as it takes a long time 2 connect and stuff...but yahoopops works and generally does a good job...u can get ur spymac settings frm the email that spymac sent u after u confirmed the email account....
Nemesis is offline
Old 06-10-2004, 09:34 PM   #10 (permalink)
tuxfan's Avatar
But I have faced some problems with YahooPops when the mail has attachment. Please bear that in mind. I don't know if later versions have taken care of the problem.
tuxfan is offline
- by bhaskar
- by soumya
