Old 02-10-2005, 07:30 PM   #1 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default phpMyAdmin Problem
I have a CPanel Hosting. I uploaded phpBB forum from my PC and created database and user manually. When I access phpMyAdmin it says no privileges but I have added that user to my database and has full privileges. What to do?
navjotjsingh is offline
Old 03-10-2005, 02:05 AM   #2 (permalink)
alib_i's Avatar
what authentication method are you using ?
check your "config.inc.php" file
$cfg['Servers'][$i]['auth_type']     = 'http';    // Authentication method (config, http or cookie based)?
$cfg['Servers'][$i]['user']          = '';      // MySQL user
$cfg['Servers'][$i]['password']      = '';          // MySQL password (only needed
                                                    // with 'config' auth_type)
if using the config method .. then u need to specify the username/passw there in the file
if using http method then leave it blank
this page: http://internetmaster.com/installtut...ad_myadmin.htm
has good info about setting up phpmyadmin
alibi
-Metallica
alib_i is offline
Old 03-10-2005, 10:56 AM   #3 (permalink)
Version 2.0
Deep's Avatar
Default Re: phpMyAdmin Problem
I hope you selected DB from the dropdown menu on the left.
It shows no privileges when you open phpmyadmin, the message is for no privileges to create new database from PHPMyAdmin...
So select DB from the database and things will work
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
- by bhaskar
- by soumya
