Old 02-10-2005, 10:56 AM   #1 (permalink)
jiteshbhimani's Avatar
Default Hard Disk (BAD SECTORS) REPAIR?
Hi Friends,
I have Seagate 40GB HDD and now it is detected but i am not able to format it. I mean the computer HANGS whenever i try to format it.
I also used Partition Magic, but it get stuck on 94%.
I used one software (Disk Repair) which shows PHYSICAL BAD SECTORS.
I know it is not possible to Repair Physical Bad Sectors but i found one software named HDD REGENERATOR which claims to do it.
Also some noise (tak-tak) is coming from my HDD.
What should i do?
Jitu........................
jiteshbhimani is offline
Old 02-10-2005, 01:51 PM   #2 (permalink)
sms_solver's Avatar
u should buy new hard disk, before that a solution is there for you.
Partition for HDD using ransih or something similar. Make 3 to 4 partitions, format the partitions leaving the partition that have bad sectors. This could be temp solution. And u may able to use your hdd for few months.
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 02-10-2005, 02:25 PM   #3 (permalink)
vignesh's Avatar
did you try scandisk?I had this problem to and was solved using scandisk.
vignesh is offline
Old 07-10-2005, 11:28 PM   #4 (permalink)
puja399's Avatar
Visit the seagate website and download the Seatools (free). The ISO version, if written on a CD, will be bootable, from there u can format, zero fill or check ur HDD.
puja399 is offline
- by bhaskar
- by soumya
