Old 01-10-2005, 10:34 PM   #1 (permalink)
gdatuk's Avatar
Default avi to GIF convertor
can someone tell me the application to convert avi clips to gif images?
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 01-10-2005, 11:50 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
There are lot of softwares aviailable on Google at http://www.google.com/search?sourcei...n&q=avi+to+gif
navjotjsingh is offline
Old 02-10-2005, 12:04 AM   #3 (permalink)
use jasc animation shop pro.... comes default with paint shop pro.
Just load the avi file and save it as gif.... + u can give many effects!!!
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 02-10-2005, 12:06 AM   #4 (permalink)
I am Optimus Prime
It does not come default with Paint shop Pro. You have to download it separately.
Old 02-10-2005, 12:08 AM   #5 (permalink)
hehe... then it did come for me...
Old 02-10-2005, 05:14 AM   #6 (permalink)
expertno.1's Avatar
Virtual dub wil convert your avi file to bmp
then by using irfan view convert those to gif
mind it u r asking for images of gif files and not animations
virtual dub will take out eac frame and save it as bmp and then by batch convert irfan view will do the rest
http://www.virtualdub.org/
http://www.irfanview.com/
both are freeares
Thanks
REgards..
Expertno.1
expertno.1 is offline
Old 02-10-2005, 12:27 PM   #7 (permalink)
gdatuk's Avatar
if it does not comes with paintshop..do we need to get any plugging?
ill try virtual dub as well
Twitter @cgiridhar
gdatuk is offline
Old 02-10-2005, 02:27 PM   #8 (permalink)
vignesh's Avatar
Use GIMP its free and the best in imaging in the Free world.
vignesh is offline
- by bhaskar
- by soumya
