Old 01-10-2005, 07:01 PM   #1 (permalink)
Caballero de Real Madrid
m-jeri's Avatar
Default Config On 50k System Needed
Hi,
After a long time.I am going to buy a pc based on amd64
for 50k.Please give a good configuration Please
My requirements are.
1)Which is good 734 or 939 pin
2)motherboard must have PCIe and good upgradability
options for future proof
3) KICK ASS SOUND system is a must
ie. good seperate sound card and 5.1 spk system
(ps. thinking about audigy and a 5.1 thx from creative or altec
or creative inspire 570sd
ie. for sound about 18K)
4)medium gaming like 6200/6600 with 128/256 mb ram
with 128 bit memory interface..
5)good smps but no fancy towers needed like antec
Please respond
|PC-15R-i3 M530|3GB DDR3|320GB|5470 512MB|500 GB Ext|D/L-D410PT|1GB|500GB|E122|APEX MI - 100|A/V-E2200HD|PS3 80GB+AT90USB162|Z5500 D|10TB|MOMO Wheel|APC 1KV|Click-500D|18-55 IS|
m-jeri is offline
Old 01-10-2005, 08:08 PM   #2 (permalink)
gxsaurav
Posts: n/a
1) Socket 939 is better
2) Asus A8N-E rev.2, make sure it's rev.2
3) Audigy Value with Speakers of your choice, listen before u buy. Although i would recomend that U stick to the onboard audio & get an inspire 5.1 speaker system
4) XFX Geforce 6600 non ultra with 128 MB RAM, or Gigabyte 6600non ultra
5) Colorsit M330U-PNE, 12 CM silent SMPS, make sure u get the necessary 24-pin model
Old 01-10-2005, 08:30 PM   #3 (permalink)
Socket 939 is definitely the way to go.
For a kick ass sound system, i would recommend you stick to the onboard sound, and get the best 5.1 speaker system from Creative/Altec Lansing that you can afford.
A geforce 6600 is great for casual gamers
Finally, get a cabinet from a reputed company, like iBall or Zebronics, and the smps tht comes with it shld be fine.
wolfff is offline
- by bhaskar
- by soumya
