Old 01-10-2005, 01:52 PM   #1 (permalink)
speedyguy's Avatar
Default Screen Turns Blue....???
this is quite strange for me as i vitnessed this for d 1st time...
my screen turns much bluish at times...regardless of anything.....it comes back to normal at its own wit its convienience.....
ps:- no this is not software or driver or any windows application issue coz i observed dis even on boot menu...ne1 experienced wit somthing like dis....
my cnfg is-
Pentium 4 1.8GHz @ i845GV chipset,
256MB DDR,
ATi Radeon 9200SE Series (128MB),
DVD, CD-RW Drives,
40 GB HDD,
Network at Dial-up proxy or Airtel GPRS connection.
now is this a grphic card issue....or any heating problem.....i dun think radeon 9200 has a cooling fan n neither does it require one....shud i go for more cooling options....my cab is not that well ventilated as i suppose (frontech)....just d 2 fans one wit cpu n other at d power supply....can i attach more cooling fans here though its got only one socket for fans....waiting for response...thanx in advance
cheers
No Pain...No Gain
speedyguy is offline
Old 01-10-2005, 02:00 PM   #2 (permalink)
is it possible that the monitor cable has been damaged a bit?... I have a monitor that turns yellow slightly. Try adjusting the cable a bit and see if there is any change...
Arun
sakumar79 is offline
Old 01-10-2005, 09:28 PM   #3 (permalink)
I've too was having a similar probelm......which occurs when ram is faulty. I replaced my 128MB ram with a new one and everything is fine now.
jack// ani is offline
Old 03-10-2005, 12:49 AM   #4 (permalink)
speedyguy's Avatar
well gotcha....twas same on again this evening...n i hit my monitor wit my hands n it turned back to normal.....so there some some monitor fault....its working on hammering by hands....the problem is...its increasing wit time....rite now im typing wit this damn bluish screen...hitting everytime i dun feel gud abt that.....wat shud be here wit this....
No Pain...No Gain
Old 03-10-2005, 08:34 AM   #5 (permalink)
Oh....I was also expereinced a silimar thing, after beating the monitor it turns normal.....but it happens. When I replaced my faulty ram it never happened again....so that means my monitor was alright!!!!!!!
Old 03-10-2005, 12:11 PM   #6 (permalink)
speedyguy's Avatar
now how is dat possible man....wen its clear u beat ur monitor n its changing.....cant be any ram fault....i guess theres some prob wit my crt...have to get it checked b4 its completely damaged n i wont even get any resale value for d new one.....though i wud give credit to it....its lasted for 7 yrs wit all punishment of shifting n all....ever since i bought my pentium 3 back in 99....ive changed everything even keybdm mouse n all...only monitor was left....one last suggestion i need is whether i shud go for replacement or try gettin it fixed by a vendor.....will i get resale value for this...rite now so far since morning its working gud....this is lg studioworks 45v.....any advice...
cheers
No Pain...No Gain
Old 03-10-2005, 12:13 PM   #7 (permalink)
speedyguy's Avatar
cheers
No Pain...No Gain
Old 03-10-2005, 01:34 PM   #8 (permalink)
There is a problem with the internal circuitory of ur monitor. But there's nothing to worry about. One if the small parts on the PCB of ur monitor is loose. Not a big issue. Just get it checked by a technician.
And that's why it works perfectly on hammering.
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 04-10-2005, 07:13 AM   #9 (permalink)
q3_abhi's Avatar
Exactly the same problem with me. My monitor is as old as 6 yrs.
Everytime i hit it.
Change the cable. Or replace it
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 21-11-2005, 02:52 PM   #10 (permalink)
speedyguy's Avatar
well how can it come down 2 cable...wen things look quite clear....so far its so gud but can be same anytime lets c..wil get it checked...
cheers
No Pain...No Gain
Old 21-11-2005, 08:02 PM   #11 (permalink)
shariq_pj's Avatar
Remove the monitor cabe and find out if there's any bend in the pins that are projectin out...
Try out with a different cable if u could happen to get ur hands on one...
Sh@riq
<size=24>P R ! V ! L E G E</size>
shariq_pj is offline
Old 07-12-2005, 01:16 PM   #12 (permalink)
speedyguy's Avatar
sorry guys for being out so long....im back home on vacations....now thanx a lot q3_abhi shariq_pj sakumar79
actually its indeed a cable fault....wen i play wit its power cable behind d screen changes.....now if itsa socket problem or cable problem i dunno but its gaining n i need to rectify it soon....ne idea how much a monitor cable wud cost
ps:- hitting was working coz of jerk twas providing to d cable....
cheers
No Pain...No Gain
- by bhaskar
- by soumya
