Old 01-10-2005, 06:33 AM   #1 (permalink)
Default Where to get Ide to Sata card/cable/convertor etc
Where to get Ide to Sata card/cable/convertor etc in bombay
i want to connect dvd drive to motherboard but it does not have slot
please help
please
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 01-10-2005, 01:17 PM   #2 (permalink)
speedyguy's Avatar
cmon man,
those cables r available at any hardware shop near u....just checkout d closest vendor around u.....ide cables as i know are available cheap in d market......provided quality proportionals price.....
cheers
No Pain...No Gain
speedyguy is offline
Old 01-10-2005, 09:20 PM   #3 (permalink)
My motherboard is not having SATA port can I use a SATA HDD, is there any such SATA to IDE converter cable?
Thanks
jack// ani is offline
Old 01-10-2005, 09:20 PM   #4 (permalink)
Thanks
Old 02-10-2005, 02:06 AM   #5 (permalink)
Originally Posted by speedyguy
cmon man,
cheers
Man i am asking ide to sata to connect my dvd drive to sata port
i have done enquiry and i got ide card but it supports hard disk not dvd or cd drive
also manual says it didnt support drives
please tell where in bombay i can get it and their tel number by pm
thanks
thanks
i will be thankfull to you
AMIT AGARWAL
Old 03-10-2005, 12:52 AM   #6 (permalink)
speedyguy's Avatar
well though i dun live in mumbai but i have lotsa ppl in touch conerned wit hardware...i'll see if i can do anything....gimmi some time...will check...meanwhile u keep trying
but man how come u dun have ide slot in ur mobo...it shud have 2 ide slots (ide1 n ide2) n u can use dvd, hdd n cd drives as pri master, slave etc. newez im trying frm my side....gud luk
cheers
No Pain...No Gain
Old 03-10-2005, 12:54 AM   #7 (permalink)
speedyguy's Avatar
well though i dun live in mumbai but i have lotsa ppl in touch conerned wit hardware there...i'll see if i can do anything....gimmi some time...will check...meanwhile u keep trying
cheers
No Pain...No Gain
Old 03-10-2005, 01:05 AM   #8 (permalink)
thanks speedyguy for your reply
i have asrock motherboard it has 1 ide slot
i have 2 hard disk
1 dvd writer
1 dvd drive that i dont want to keep as i have purcahsed it 6 months ago
so i needed 4 ide to connect
please help if u can
ide card that is in market is raid and does not support dvd or cd drive. though seller says it supports.but in manual it tells no
AMIT AGARWAL
Old 03-10-2005, 12:58 PM   #9 (permalink)
speedyguy's Avatar
1st of all i apologise for that double post...may be due to my network problem here...
@amit:
so u mean u need ide for 2 hdd n 2 dvd drive...thats 4 or ie 2 ide slots n u have only 1 ide slot so u can connect only 2 ide drives....well lets c here...will look for ide to sata
cheers
No Pain...No Gain
Old 04-10-2005, 12:53 AM   #10 (permalink)
no i want currently 1 etc ide port for dvd drive to connect
but if possible 2 ide ports will be nice if available.
yes i needed need ide for 2 hdd n 2 dvd drive
so 2 drives . in that i have purchased ide card so hard disk is connected
now remaining is dvd drive
AMIT AGARWAL
Old 07-10-2005, 11:19 PM   #11 (permalink)
puja399's Avatar
Why do u want to convert ur SATA ports to IDE? Why don't u buy one IDE card, put it in a free PCI slot and get 2 IDE ports? Duh..!!
puja399 is offline
Old 08-10-2005, 03:26 AM   #12 (permalink)
i have bought ide card puja399
and i can connect hard disk to it
dvd or cd drive didnt work on that
it is not detected
thanks
AMIT AGARWAL
- by bhaskar
- by soumya
