Old 30-09-2005, 12:13 PM   #1 (permalink)
Default how many time we can format the hard drive?
how many time we can format the hard drive?And how frequent we can format the drive?is any problem will arise?
rajas700 is offline
Old 30-09-2005, 12:15 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
netime, newhere, ne how, ne method
I usually format my HDD once a month approx.
No Harm!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 30-09-2005, 12:56 PM   #3 (permalink)
ok.i heard that once we format the drive the thing in the drive were not deleted only windows image itself as deleted.so if we go on deleteing some software how much data can be stored in 80 g.b drive?(how much gb will image as deleted0
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 30-09-2005, 01:25 PM   #4 (permalink)
Just Do It
Charley's Avatar
Wht do u mean by the image? Pls rephrase the query for better understanding.
Charley is offline
Old 30-09-2005, 02:33 PM   #5 (permalink)
sms_solver's Avatar
LIfe of hard disk according to me is 5 years, so you can format your hard disk at least 5 times (once in a year)
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 30-09-2005, 02:40 PM   #6 (permalink)
__Virus__'s Avatar
its not specific that hadd MUST work for 5 or XX amount of time.....but one thing everytime u format ur hard drive u lesses its life FOR SURE ...in the past 2 yrs i have formatted my disk for some 60-90 times (kiddin) and one of my friend who nvr formatted ..i can c the diff............
__Virus__ is offline
Old 30-09-2005, 04:36 PM   #7 (permalink)
String Phreak
mediator's Avatar
Well i must have partitioned my hardisk like 20 times in the last 3 years and still perfectly running.
mediator is offline
Old 30-09-2005, 04:46 PM   #8 (permalink)
__Virus__'s Avatar
cant even remember how many times i did that....once it was like 5 times in a day....cos i was a noob at linux partitions there and resst need not b said
Old 30-09-2005, 06:30 PM   #9 (permalink)
I Format my computer within a month everytime
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 30-09-2005, 06:42 PM   #10 (permalink)
I format my hdd every month no harm formatting does not cause any harm to hdd....
Regards...
shivaranjan.b is offline
Old 30-09-2005, 07:54 PM   #11 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Just do a quick format insted of a full format.
kalpik is offline
Old 30-09-2005, 08:06 PM   #12 (permalink)
__Virus__'s Avatar
Regards...
no harm....but its lessens the life...
and someone told abou quick formatting...yup it doesnt effects as much as full format
Old 30-09-2005, 09:17 PM   #13 (permalink)
d
dudes......get a life!!formatting the hdd is just redrawing the tracks and sectors on the media....so formatting in essence is just like writing to a disk...doesnt lessen the life of the disc any more than me owning microsoft.
The torquemaster rules.
d is offline
Old 30-09-2005, 09:17 PM   #14 (permalink)
Fresh Stock Since 2005
I agree..... Quick format is just like deleting files. it is quite fast and quite good.................
http://www.khattam.info
khattam_ is offline
Old 30-09-2005, 10:55 PM   #15 (permalink)
actually quick format DOESNT delete the files
it just removes the files entry from the partition table
and quick or full .. it wont make a different ...
low level formats decrease capacity of hdd .. which we dun normally do .. and thankfull dont ahve an option for unless we use specific software for
No Mercy, No Limits.
theraven is offline
Old 30-09-2005, 11:02 PM   #16 (permalink)
__Virus__'s Avatar
preach what u teach......
get 2 hdd... format one 100 times and dont format other one.... install some os...u will know the difference
EDIT: i brought one practical example of me and my friend...
Old 30-09-2005, 11:42 PM   #17 (permalink)
9437077259
go4saket's Avatar
Hello! I dont think formatting does any harm to your HDD, specially quick formatting. I have been doing it regularly since the last six to seven years but my HDD still works great. So just dont worry and format your HDD...
go4saket is offline
Old 30-09-2005, 11:55 PM   #18 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Heh .. If the posts in General Discussion hadnt pruned you'd have found my old posts ...
Formatting a drive cannot and doesnot do any harm to the hard disk .. Format program actually recreates the File Allocation Table that is the address of files, sectors alloted to them and all that .. It does not touch the media so no question of any harm . ..
Now what people normally refer to as low level format .. They are actually referring to Zero Fill .. What this program does is to initialize all the sectors of hard drive to zero .. so the data is wiped away .. This is time consuming process as each and every sector is read and write .. Bad sectors can be found here (Found and not created) as if some part of drive doesnt respond in the manner it should, it is marked as bad sector .. So the program doesnt do anything to the physical media ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 01-10-2005, 12:00 AM   #19 (permalink)
godsownman's Avatar
Is this true because mine is over 5 years.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 01-10-2005, 06:30 AM   #20 (permalink)
d
hi virus....sure thing, buddy, as long as you pay for the hard-drive......i'm not xactly loaded....and i'm getting tired of my fx-5200...so i'd rather spend on that than a second hard-drive to format a hundred times. jus give me ur credit card no., plzz
d is offline
Old 01-10-2005, 09:50 AM   #21 (permalink)
gxsaurav
Posts: n/a
I format only when reinstalling windows, although i did formatted my d: drive 1 year back
Old 01-10-2005, 10:07 AM   #22 (permalink)
godsownman's Avatar
Please correct me if I am wrong , But after you format you have to reload windows so everybody does it like that .
But I dont understand , people here are saying that they format ever so often like once a month . How does help?
Old 01-10-2005, 06:56 PM   #23 (permalink)
9437077259
go4saket's Avatar
Noone enjoys to reinstall Windows again and again. Its only when your system gets very slow or starts hanging up because of new softwares or games installed or for some other error. Reinstalling Windows is the best remedy available.
go4saket is offline
- by bhaskar
- by soumya
