Old 29-09-2005, 11:04 PM   #1 (permalink)
Default A Multiple Net question
I have 2 connections : Iqara and Sify
Now Iqara is on USB and Sify comes on LAN wire and 2 local area connections are made..
Is it possible to switch on both and make programs specific to use specific connection..
Cause suppose i dont connect to SIFY on net ( U have to dial for it ) and wanna use IP messenger on Sify and rest all on Iqara.. can i define this somehow..
I dont think so.. but just givin a try..
I\'M BACK
khandu is offline
Old 30-09-2005, 12:08 AM   #2 (permalink)
umm no
i dun think so
u can define both connections to work as one by bridging them
but i dun think u can specify
No Mercy, No Limits.
theraven is offline
Old 30-09-2005, 11:32 AM   #3 (permalink)
siriusb's Avatar
I think it is possible by altering the routing table manually, though I haven't tried it but I think I have seen it somewhere. Even if applicaton level redirection to different isp is not possible, you can seggregate traffic based on destination network, if this is possible.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
- by bhaskar
- by soumya
