Old 29-09-2005, 08:54 PM   #1 (permalink)
Default Suggestions needed for 70k system...
hi friendz. need your help with this configuration. budget limit is 70,000...plz advise...thx
- ASUS A8N Sli Premium
- AMD 64 bit 3500+
- Transcend 1 GB 400Mhz RAM
- Seagate 120GB SATA
- XFX Ge force 6600GT 256 MB
- Creative Sound Blaster Audigy 2 NX 1 (External)
- Creative 7.1 Inspire 7790
- Samsing 17'' Dyna Flat.
- Sony DVD Writer (DRU - 810 A)
- APC 1000V...
--Cabinet...help!!
Is this OK?? Any suggestions plz. I would like to have fair deal for 70K... Thx
panzer is offline
Old 29-09-2005, 10:25 PM   #2 (permalink)
Aniruddh's Avatar
its gud but u can get betta thins.like u can go for sata2 as now its available and ur mobo do support it then why sata u can go for hitachi sata2 and de price is almost the same.instead of sli u go for Asus A8NE mobo wid 6800gt/Ultra.i dun think APC1000VA is needed go for APC800VA and dun forget to go for smps u can go for either of these antec(recommended) or coolermaster 400w minimum.u can hav a look at antec lansing and logitech speakers they r really gud.
Aniruddh is offline
Old 29-09-2005, 10:36 PM   #3 (permalink)
>>thx 4 da hard drive suuggestn. but what is wrong with creative inspire 7900... and wats the price of altec lasing. i'm looking for good speakers with surround . and is the sound card good enough??
panzer is offline
Old 29-09-2005, 10:43 PM   #4 (permalink)
Aniruddh's Avatar
i m not sayin dat creative is bad or sumthin.for how much u r gettin dat creative speakers?
Aniruddh is offline
Old 29-09-2005, 10:44 PM   #5 (permalink)
rs.8000...hyd
panzer is offline
Old 29-09-2005, 10:52 PM   #6 (permalink)
Aniruddh's Avatar
then u hav betta options from altec lansing and logitech.if u can spend 12k for speakers then u can get logitech Z5300 subwoofer 100w rms,center 39w rms,satellites 36w rms.i m sure others wil tellu more bout the speakers specially altec lansing.
Aniruddh is offline
Old 29-09-2005, 10:56 PM   #7 (permalink)
thx 4 the options. .will think 'bout thx. is da sound card good enough or internal would be better??
panzer is offline
Old 29-09-2005, 11:02 PM   #8 (permalink)
Aniruddh's Avatar
well onboard sound is gud but as i dun hav much idea bout sound card so cant tellu how gud ur card is.but if u go for a SLI mobo den go for MSI K8N Diamond dis is the best Nforce4 SLI mobo.it has Creative sound Blaster Live 24-bit onboard audio so dun hav to go for a external card.
Aniruddh is offline
Old 29-09-2005, 11:17 PM   #9 (permalink)
yogi7272's Avatar
Just one suggestion , go for benq dw 1640 instead of sony dru 810a cos the sony model is a rebaged benq 1640
Why r u going for sony when the original is available .. 8)
I am using one and its a great dvd writer .. trust me ..
Infact most people on net are saying that it is one of the best dvd writers of all time ..
yogi7272 is offline
Old 29-09-2005, 11:21 PM   #10 (permalink)
yogi7272's Avatar
yogi7272 is offline
Old 29-09-2005, 11:51 PM   #11 (permalink)
listen to anirudh...he's got some nice suggestions...btw i recently got my system frm hyd.... in case u need some help u are welcome
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
Old 30-09-2005, 12:04 AM   #12 (permalink)
Get bigger HD's like min 160 or 200GB's. DONT GET SEAGATE!!!!!! They make weird noises. And I have used 100's of HD's and this sound makes me fall off the chair and miss a few heart beats every time I hear it.
Get 2 GB of ram. You can always use extra ram for disk cache if the programs dont use it. Gives huge increase in performance.
Why SLI? unless you think you are going for 2 GFX cards. 750VA UPS is more than enough even 600VA will work just fine for single computer/monitor/modem.
Get the best SMPS supply you can, it is the most important component for stability.
AlienTech is offline
Old 30-09-2005, 08:10 AM   #13 (permalink)
Learner
Kniwor's Avatar
Just one question, do u plan to upgrade ur ram sometime later?
Are u getting one single stick of 1Gb?
If u plan on upgrading sometime soon it's fine, otherwise i would suggest get 2x512Mb, u will that will be better performer, there is a lot of difference in single and dual channel.
just let me know.
Kniwor is offline
Old 30-09-2005, 08:12 AM   #14 (permalink)
Learner
Kniwor's Avatar
also a quick question?
why do u want to spend on SLI?
it's useless unless u use 2 gfx cards.
Kniwor is offline
Old 30-09-2005, 10:48 AM   #15 (permalink)
Manchester United
abhijit_reddevil's Avatar
Yes, I agree, do not go for SLI motherboard unless you have two graphics cards. The best non-SLI board is Asus A8N-E in terms of price and performance and overclocking options. 8) Go buy this unless you are bent on SLI and want to add another graphics card, maybe not at present but a few months later. 8)
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 30-09-2005, 03:46 PM   #16 (permalink)
rohanbee's Avatar
well if the price difference is not too much a sli board would be worth it even if you are not planning another graphics card in the near future........but one never knows............if you have the facility you just might be tempted....
Quote by Garfield'
rohanbee is offline
Old 30-09-2005, 06:46 PM   #17 (permalink)
thx guys...u guys were "gr8".
panzer is offline
Old 01-10-2005, 01:58 PM   #18 (permalink)
royal's Avatar
hey for Cabinet+PSU go for Antec...
Antec
Company:- Prime ABGB [Mr Gulbir Singh @ Mumbai]
Contact:- 022-2896600 , 022-23855500
Email:- primeservices@vsnl.com
Web:- www.antecindia.com
royal is offline
Old 03-10-2005, 06:02 PM   #19 (permalink)
thanks 4 that.
but...
can anyone give an antec dealer's address in hyderabad??....
panzer is offline
- by bhaskar
- by soumya
