Old 29-09-2005, 11:22 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Enable javascript ! ! !
recently i got a popup from IE6 while surfing ... it says "ur javascript is disabled" ...
how do i enable it in IE 6???
ax3 is offline
Old 29-09-2005, 12:17 PM   #2 (permalink)
tuxfan's Avatar
Originally Posted by Microsoft Knowledge Base
Enable JavaScript
Microsoft Internet Explorer 5 or Later
1. On the Tools menu, click Internet Options.
2. On the Security tab, click Internet.
3. Click Default Level, and then click OK.
If the issue continues to occur: 1. On the Tools menu, click Internet Options.
2. On the Security tab, click Internet, and then click Custom Level.
3. Under Active scripting, click Enable or Prompt.
4. Click OK, and then click Yes.
5. Click OK.
Internet Explorer 4.x
1. On the View menu, click Internet Options.
2. Click the Security tab.
3. In the Zone box, click Internet Zone, and then click Reset.
4. Click OK.
If the issue continues to occur: 1. On the View menu, click Internet Options.
3. In the Zone box, click Internet Zone.
4. Click Custom (For Expert Users), and then click Settings.
5. Under Active Scripting, click Enable or Prompt.
6. Click OK, and then click OK again.
http://support.microsoft.com/default...b;en-us;236846
tuxfan is offline
Old 30-09-2005, 10:40 AM   #3 (permalink)
ax3
ax3's Avatar
thanx ...
... W H O T ...
ax3 is offline
Old 30-09-2005, 11:38 AM   #4 (permalink)
tuxfan's Avatar
You are welcome
tuxfan is offline
- by bhaskar
- by soumya
