Old 29-09-2005, 06:50 AM   #1 (permalink)
Default PC Upgrades
hi. i have P IV 2.4 GHz on Intel 845 GERG2 Mobo with GeForce MX440 and 256 MB RAM. Pl suggest upgrades for Gaming
sudhirkumar001 is offline
Old 29-09-2005, 08:26 AM   #2 (permalink)
Budget? Please post your budget first so that you get reasonable responses. You don't want people replying with ultra-high end configurations that will burn a big hole in your pocket.
Nemesis is offline
Old 29-09-2005, 12:33 PM   #3 (permalink)
gxsaurav
Posts: n/a
upgrade your gfx card to a 6600non ultra or 6600GT AGP
Upgrade your RAM to 512 MB
this is just an advice as U haven't given any budget
Old 01-10-2005, 10:14 PM   #4 (permalink)
Thanks for your advice. Another problem is that although i hav a 17 inch CRT, I get a maximum visible display of 15.7 inch only. when i start my comp it starts with a lot of flickering and horizontal lines.it settles when the windows xp welcome screen appears, bt display is stuck at 15.7 inches.
Old 01-10-2005, 11:13 PM   #5 (permalink)
Aniruddh's Avatar
well can u c in ur monitor its written LG thats the problem nothin else.m i write sudhirkumar that you hav a LG monitor?
Aniruddh is offline
- by bhaskar
- by soumya
