I bought 4 discs of MoserBaer (Fujify make discs) which were all burnt successfully..... with min possible errors.....
FUJIFILM made discs are SECOND CLASS discs while MBI (MOSERBAER INDIA) made ones are THIRD CLASS as suggested by the following article....
http://www.digitalfaq.com/media/dvdmedia.htm
Media ID Quality Guide
The following list is in preference order. The best discs are near the top of the list. The discs at the bottom of the list are suitable only for a landfill. PVC is the best of all, LONGTEN is the worst of all, etc. Note: Some codes may be listed twice, done because a -R, -RW, +RW and +R by the same company may not be the same quality. The format is listed because of this.
1ST CLASS MEDIA
Almost flawless burns with 95-100% reliable results:
PVC = Pioneer (Japan) = (-R)(-RW) ... media is no longer made
MXLRG0x = Maxell (Japan) = (-R)(-RW)
YUDEN, TYG01/TYG02 = Taiyo Yuden (Japan) = (-R)(+R)
MCC, MKM = Mitsubishi Chemicals (Singapore/Taiwan) = (-R)(-RW)(+R)(+RW)
TDKG02, TTG0x, TTH0x = TDK Corp (Taiwan/Japan) = (-R)(-RW)
SONY0xD = Sony (Japan/Taiwan) = (-R)(-RW)
2ND CLASS MEDIA
Decent discs, though not perfect, about 80-95% success rate:
PRODISC = Prodisc Media (Taiwan) = (-R)(+R)
INFODISC = Infodisc Media = (+RW)
RICOHJPN = Ritek or Ricoh (Taiwan) = (+R)(+RW)
FUJIFILM = Fuji = (-R)(+R)
OPTODISC = Optodisc = (-R)
RITEK = Ritek (Taiwan) = (+R)(-R)(-RW)(+RW)
3RD CLASS MEDIA
Quality can be very questionable, about 50-80% success rate:
LEADDATA, LD01, LD, LEDA = Lead Data = (-R)(-RW)
BEALL = Samsung BeAll = (-R)(+R)
MBI = Moser Beaur (India) = (-R)(+R)(+RW)
MAMA = Mitsui = (-R)
PRINCO, fake TDK = Princo = (-R)(-RW)
ONIDTECH = Unknown OEM = (-R)
MUST = Unknown OEM = (-R)
GSC001, GSC002 = Unknown OEM = (-R)(+R)
CMC, CMCMAG = CMC Magnetics = (+R)
4TH CLASS MEDIA
Pathetic garbage media, landfill material, about 0-50% success rate:
CMC, CMCMAG = CMC Magnetics (Taiwan) = (-R)
PIODATA, PIO = LeadData, Ritek = (-R) ... once sold as "Pioneer" but that's false
Fake TYG02, SONY, MXL = Fake Sony/Maxell from Hong Kong OEM (Infosmart) = (-R)
OPTODISC = Optodisc = (+R)(+RW)
AN31, AN32, ANWELL, AN30, AML = Hong Kong OEM (Infosmart) = (-R)
INFOSMART = Hong Kong OEM = (-R)(+R)
DAXON = BenQ/Acer (+R)(-R)
VANGUARD = Unknown OEM = (-R)
YIJHAN = Hong Kong OEM = (-R)
MATRIX = Hong Kong OEM = (-R)
ISO001 = Unknown OEM = (+R)
VDSPMS = Unknown OEM = (-R)(+R)
LONGTEN = Hong Kong OEM = (-R)
ANYTHING ELSE = Unknown OEM or NEW
from there u can see that FUJI discs r better than MBI discs...
also I am providing a picture of Kprobe scan of my Fuji disc......
