hi,
i was downloading a file, when my computer got hanged and i had to reset... then for a while my hardisk was not detected(160 GB seagate). i then changed the power supply and everything worked fine. but now i find that i cudnt get the task manager window with "ctrl+alt+del". nothing happens with that.. i had to rightclick on taskbar to get the task manager. and even if i hit the shutdown button or restart button... nothing happens! pls help me... thk u.
/legolas
