Old 28-09-2005, 11:42 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Corrupt zip files ! ! !
i did download a zip file of 6mb using free download manager ... bt after downloading was complete, i checked it ... bt it turned out 2 b corrupt ...
file was resume-able & connection didnt breakup @ anytime ...
how can u avoid downloading corrupt files or can those b repaired ???
ax3 is offline
Old 28-09-2005, 11:47 AM   #2 (permalink)
Netjunkie's Avatar
I use PowerArchiver to repair Zip files, it recovers maximum of the data from the corrupt archive.
Not sure if there are any better softwares available but you can give it a try.
Netjunkie is offline
Old 28-09-2005, 04:06 PM   #3 (permalink)
expertno.1's Avatar
1) If the file is corrupt on the server then even downlaoding it will not help you
for better downlaoding use dl managers like DAP and FDM
2)these can be repaired (45% chance)
by using Power archiver
get it from here
http://www.powerarchiver.com/download/
Thanks
Regardss.
Expertno.1
expertno.1 is offline
- by bhaskar
- by soumya
