XPlite and 2000lite are powerful configuration utilities for Windows creating a modular Windows operating system where YOU are in control.
The new version 1.5 gives you more than 150 ways to reduce the size,
improve the security, and customize YOUR Windows XP or 2000
installation to suit YOU.
Its a very good s/w, no doubts.
But when I got nLite, I never used XPlite again!!!
Because I always remove those un necessary components from setup directly, so what use of it after installing the OS...
i agree
nLite is awesome and offers many more features then xplite
for example integration of service packs and hot fixes
integration of many other components
tweaks
and ofcourse unattended cd setup
along with file protection removal and uxtheme patching ... AND tcp/ip limit changing ..
id suggest teh use of nLite over XPLite as well
No Mercy, No Limits.
U can't compare XPlite with nLite.
Both r different.
One removes components after the installation ( XPlite ) and one removes the components b4 the installation ( nLite ).
And of cource nLite can be used for many other stuffs not only removing components from setup...
