Old 28-09-2005, 06:28 AM   #1 (permalink)
Fresh Stock Since 2005
Default Exact Backup copy of HDD
Hi ppl.......
I need help....
Can I make the exact backup copy of an entire harddisk on the harddisk of same size or larger than that size?? If it is possible, how can I do it or what utils should I use...... Please help.........
http://www.khattam.info
khattam_ is offline
Old 28-09-2005, 06:47 AM   #2 (permalink)
expertno.1's Avatar
I would suggest you to use HDclone
http://www.miray.de/download/sat.hdclone.html
Thanks
REgards.
Expertno.1
expertno.1 is offline
Old 28-09-2005, 07:39 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Try Acronis TrueImage
kalpik is offline
Old 29-09-2005, 02:45 AM   #4 (permalink)
sba
Another vote for TrueImage. Not only b'cos it makes excellent copies but for the reason that you can mount the image as a drive whenever you want and access the files from the it.
sba is offline
Old 29-09-2005, 02:13 PM   #5 (permalink)
bukaida's Avatar
use norton ghost.It is automatic but not a free software though.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 29-09-2005, 08:55 PM   #6 (permalink)
Thanks everyone....... Will try 'em and report........
khattam_ is offline
Old 29-09-2005, 08:57 PM   #7 (permalink)
khattam_ is offline
Old 30-09-2005, 09:08 PM   #8 (permalink)
Thanks
REgards.
Expertno.1
This one is great. Acronis True Image is being Downloaded......... Thank sagain guyz............
khattam_ is offline
- by bhaskar
- by soumya
