Old 27-09-2005, 09:53 PM   #1 (permalink)
godsownman's Avatar
Default Embed fonts in powerpoint
I have to present my powerpoint presentation tommorrow in front of 60 people.
Now since I dont want any blunders , I want to make sure that the FONTS that I have used do not betray me at the last moment
90% of the fonts used are Fancy and are not there in office 2002 version.
I have tried to package it but I am not burning a CD using the package option.I have created a folder on my desktop and now I shall copy it to the cd.Will it work. Here I selected the embed font option.
Also,
What will happen if I create a 'powerpoint show' , will the fonts be embedded.
Please Help me as this is urgent as I have to present it tommorrow
Thanks
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 27-09-2005, 11:39 PM   #2 (permalink)
godsownman's Avatar
HELP ME I'M RUNNING OUT OF TIME
Old 28-09-2005, 06:58 AM   #3 (permalink)
Taken from http://www.rdpslides.com/pptfaq/FAQ00076.htm
It is possible to embed fonts in your PowerPoint presentations.
PowerPoint 97
Choose File, Save As
In the Save As dialog box, check the "Embed TrueType" box under the Save and Cancel buttons
Click OK and continue saving normally
PowerPoint 2000
In the Save As dialog box, click Tools then click Embed TrueType Fonts
PowerPoint 2002, 2003
In the Save As dialog box, click Tools then Save Options
In the Save Options dialog box, put a checkmark next to "Embed TrueType fonts"
Click "Embed characters in use only" if you want smaller PPT files but don't need to let others edit the files if they don't have the embedded fonts or ...
Click "Embed all characters" if others will need to edit the presentation using the embedded fonts. This will produce larger PPT files; if you embed unicode or doublebyte fonts, the files will be MUCH larger.
But there are GOTCHAS
Mac versions of PowerPoint can't embed fonts or use fonts that have been embedded in a PC-made PowerPoint file.
Only TrueType fonts can be embedded. TrueType fonts will show up in your Windows Fonts folder with a little blue "TT" icon and there's a TT icon next to them in PowerPoint's font menus. There may be an "OT" icon in later Windows/PowerPoint versions. PostScript/Type1 fonts usually appear with a printer icon in PowerPoint; they can't be embedded.
Not all TrueType fonts can be embedded. There are four "levels" of embedding, and every TT font is assigned one either by its maker or by other software that's modified it along the way. Many fonts, especially those that have been converted from some other format like Type1, are tagged "No Embedding Allowed."
If you attempt to embed one of these fonts, PowerPoint gives you an error message saying that the font could not be saved with your presentation because of a license restriction. (Read rest from provided url)
sakumar79 is offline
Old 28-09-2005, 08:14 AM   #4 (permalink)
godsownman's Avatar
Thanks a lot .You solved my problem.
Old 28-09-2005, 05:43 PM   #5 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
And remembering Murphy's law, you should test it on a system other than yourself ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
- by bhaskar
- by soumya
