Old 27-09-2005, 09:24 PM   #1 (permalink)
Default Default Administrative Shares....
Hi,
I recently discovered that my whole of my system is being shared secretly by windows ( C$, D$, E$...)...i tried to disable it but all in vain...can anyone explain me what this is and how this can be stopped...
thanx
hearthacker is offline
Old 27-09-2005, 11:02 PM   #2 (permalink)
o its just defautl administrative shares
dun worry its not shared ont he network unless u actually enable it
for ur piece of mind u can disable it by copying following code in a file
save it with .reg extenstion
and run it
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa]
"restrictanonymous"=dword:00000001
"restrictanonymoussam"=dword:00000001
"everyoneincludesanonymous"=dword:00000000
No Mercy, No Limits.
theraven is offline
Old 28-09-2005, 10:25 AM   #3 (permalink)
and run it
I get an error doing this.
It says cannot import "filepath":Error opening the file.There may be a disk or file system error
rachitar is offline
Old 28-09-2005, 11:59 AM   #4 (permalink)
Netjunkie's Avatar
EDITED...
Netjunkie is offline
Old 28-09-2005, 01:48 PM   #5 (permalink)
WTF !!
thats the exact same thing i posted u moron
@rachitar .. what exact steps did u follow ?
anyways it wont harm ur system so dun worry !
and u can do it manually
just goto start run
type regedit
and hit enter
browse to [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Lsa]
then look for the above 3 parameters and set the appropriate value
that is double click on everyoneincludesanonymous and set the value as 0
repeat for the other 2 parameters and set value as 1
theraven is offline
Old 28-09-2005, 04:25 PM   #6 (permalink)
Netjunkie's Avatar
Hey theraven
Even i know that its the same as the one you posted.
But for some unknown reason I got some error while i tried to import it.
So i made the changes manually & exported it from the registry & posted it here.
Old 28-09-2005, 09:14 PM   #7 (permalink)
eh ?
i didnt get what u mean
but its aight .. sorry for loosing my head !
theraven is offline
Old 02-10-2005, 12:43 AM   #8 (permalink)
Default thanx
THANX raven....ur the coolest
Old 02-10-2005, 01:21 AM   #9 (permalink)
__Virus__'s Avatar
net share C$ /delete | net share D$ /delete | net share E$ /delete
is what i used the first time i installed win
__Virus__ is offline
- by bhaskar
- by soumya
