ok here's wats happening
in the bios
IDE-Primary master : st3160021a
IDE Primary slave : none
then it lists my cd rom as secondary master
and secondary slave as none
the old hdd is attached to the cable going from the new hdd to the motherboard...
now in the bios in the sub menu for ide primary slave
i had..
Ide primary slave :auto
Access mode :auto
press enter to auto detect
when i press enter it is not able to detect anything...
while when i go to the sub menu for IDE primary master... it shows capacity and the other data...
i am thinking cld it be that its not getting power
the interesting thing is that
the old HDD has a cable attached with the molex connector going in to give it power...
now that cable just dosent come out .. like it does on my new hdd... and instead it has two mroe connectore at the other end.. (like molex connectors only... one of them has pins while the other has the holes for the pins )... i connected to the one with pins to a power cable which was hanging spare in my smps ...
i had connected another drive to the same hangin cable in the smps and it worked great ..
i hope i am explaining everything properly...
i am just not able to do this man
this sux
