Old 29-09-2004, 09:27 PM   #1 (permalink)
Default Partition Magic 8.0 not working
Init Failed :Error 117
Partition's Drive letter can not be found.
i hav installed red hat 8.0 on my PC
and after installation when i started Partition magic 8.0 from XP it gave me the above prompt
let me tell u what i hav done
first i took the 6.9GB from a logical drive and created a new drive with EXT3 file sys
then created a swap space of 815MB ...
and after that installed linux
thats it...
can u tell what exactly the problem is
sagarbora is offline
Old 30-09-2004, 04:05 PM   #2 (permalink)
Not sure...try a DOS mode Partition manager
sniper is offline
Old 30-09-2004, 05:04 PM   #3 (permalink)
http://www.access-programmers.co.uk/...ad.php?t=56387
hope that helps its all i can find
theres some sort of solution there
and if uc an sign up .. also check this ..
http://www.experts-exchange.com/Oper..._20525435.html
i dunno if there is a solution there tho .. i havent signed up myself
No Mercy, No Limits.
theraven is offline
Old 03-10-2004, 04:40 PM   #4 (permalink)
Default Re: Partition Magic 8.0 not working
Dear friend i also have the same problem when running in winME but not in winxp
shivaranjan.b is offline
- by bhaskar
- by soumya
