Old 26-09-2005, 07:40 PM   #1 (permalink)
Default Porblems installing visual studio .Net
Dear friends,
I have .net(visual studio) cd with me but i am not able to install it on my pc. My pc satisfyies all the conditions for installation(both softwre and hardware critrion satisfied). Installation contains 5 cds with 2 optional cds. The problem comes when i am asked to insert the 3rd cd, and after inserting the cd on my cddrive it still prompts for the cd even after it is provided with it.
My friends used the same cd to install .net and they had no problems
Plz help.
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 26-09-2005, 07:49 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
get the original one
Also, try ISOBuster and try mounting it after the message..
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-09-2005, 10:21 AM   #3 (permalink)
royal's Avatar
try it with another cd drive... maybe ur drive cant read the disc properly
royal is offline
Old 06-10-2005, 11:56 PM   #4 (permalink)
puja399's Avatar
Default Re: Porblems installing visual studio .Net
Originally Posted by suhasingale
Dear friends,
Plz help.
Which version is it? I think its VS.Net 2002, and if yes, it contains a bug that is responsible, then get 2003, its more stable.
puja399 is offline
Old 26-01-2006, 12:43 PM   #5 (permalink)
Default Reply
Even i had the same prblm and finally i had solved this Prblm,
Cause:
Wrong CD LABEL NAME (CD3 Is labelled incorectly)
Solution Only if u hav multisession Disk)
Try and Write it again with diffrent label( it should be VSENARD03).
Good Luck
Andyiz is offline
- by bhaskar
- by soumya
