Old 26-09-2005, 04:47 PM   #1 (permalink)
linardni's Avatar
Default Collage kaise banate hai?
Do u have the idea, how to make collage with several photos?
linardni is offline
Old 26-09-2005, 05:45 PM   #2 (permalink)
yeah
use a good software like photoshop
wen u make the file, make sure the size u selected is big enough then just copy paste ur pics in there
u can just drag em in also
arrange how u want em 2 b
u can evn put effects like transparency etc
ishaan is offline
Old 26-09-2005, 06:00 PM   #3 (permalink)
linardni's Avatar
the instructions are very superficial and not precise...precise instructions plz
linardni is offline
Old 26-09-2005, 06:10 PM   #4 (permalink)
godsownman's Avatar
Why dont you use Picassa .
I dont know how many pics it can accomodate at a time .
But I know that it makes collages
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 26-09-2005, 06:10 PM   #5 (permalink)
could u specify exactly wat u want, then
how many pictures?
which format are they in?
how big is each pic (i mean resolution not size)
do u hav adobe photoshop?
do you want it for printing or just keep it on the pc or upload it on a site?
are you sure u dont mean a slideshow and u mean a collage?
and, how exactly do u want ur collage
like u want pictures to overlap a lil bit, or arranged in perfect order with gaps, without gaps, u want sum of them to be a lil transparent
or any other fx?
ishaan is offline
Old 26-09-2005, 06:56 PM   #6 (permalink)
linardni's Avatar
hello ishaan...ur reply
how many pictures ->5 or 6
which format are they in -> jpeg
how big is each pic (i mean resolution not size) ->300 dpi
do u hav adobe photoshop? ->ya
do you want it for printing or just keep it on the pc or upload it on a site? -> printing
are you sure u dont mean a slideshow and u mean a collage? -> yes, collage
like u want pictures to overlap a lil bit, or arranged in perfect order with gaps, without gaps, u want sum of them to be a lil transparent ->overlap a lil bit and having irregular edges
or any other fx? -> nope
linardni is offline
Old 26-09-2005, 07:57 PM   #7 (permalink)
godsownman's Avatar
But why not picassa , is it not good . I tried it out and i found it nice
Old 27-09-2005, 12:05 AM   #8 (permalink)
yeah picasa is a good option too. its available as a free download and its not that big...just get it from google. well ok this is how to go about it.
USING PHOTOSHOP:
open adobe photoshop. a box will come choose new file. choose the size to be the same as the size of the paper which u will print it on.
then make the window smaller. from windows explorer, drag each picture u want into photoshop. once all of them are there, u can make the window large again. then drag each picture into the position u want it to be in.
if u want irregular edges, take an eraser and make it how u want. ur done dont 4get 2 save
USING PICASA:
Use Picasa's "Collage" button to create one–of–a kind photo collages. You can even put your collage on a mug, apron, greeting card, even a mouse pad. Get started:
1. Select the pictures in Picasa that you want to appear in the collage. (Hold the Ctrl key down to select multiple pictures from different folders.) All of the selected pictures will appear in the "Picture Tray" at the bottom of the screen.
2. Click the "Collage" button at the bottom of the screen.
3. Select the type of collage and background image. For location, select "Current Folder" (by default, Picasa will save your new image to the currently highlighted folder). Click the "Create" button to finish your collage.
hope it turns out 2 b good
ishaan is offline
Old 27-09-2005, 02:56 PM   #9 (permalink)
linardni's Avatar
yaaa.....now thats what i wanted to know...thanx buddy
linardni is offline
Old 27-09-2005, 04:36 PM   #10 (permalink)
your welcome...show us how it looks...if u dont mind
ishaan is offline
- by bhaskar
- by soumya
