Samurize v1.63 has been released.
Changelog:
Bug Fixes:
* Fixed bug when saving config with no meters.
* Fixed the default values for the ToolTip
* Fixed blending problem with the Visual Plugins.
* Fixed a Selection bug in the meter list.
* Fixed a bug in the Decimal points of the Tool Tip meters.
* Fixed if blank Linkage the link is not run.
* Fixed a bug in the tray icon not changing when using the commandline options.
* Fixed the config editor not returning the language file name and config file name when using the plugin api.
* Fixed actions to ensure they are cleared correctly if a source plugin doesnt return the information.
* Fixed a bug in the alert meter image alert processing.
* Fixed bug with single click occuring with double clicks.
* Fixed problem with repeating lines in the Text Meters.
* Fixed bug with client not saving location on windows shutdown.
* Fixed a Bug with copy and pasting Visual Plugins
* Fixed Uptime meter so that it will go up-to 49 days now
* Fixed bug in upload and download
* Fixed bug with Text File meter losting the last character in a file
* Fixed bug with ToolTips not honouring %b and %tab
* Fixed bug in the Client that wasnt holding Click Through correctly
* Fixed bug in Instance Manager / client to ensure they are in step
Changes/Improvements:
* Text Shadowing.
* Transparent area color setting for Background images. (Not been added to meter images because it would significantly increase CPU usage).
* Meter Centering when selected on the meter list.
* Day ordinal has been added (used in conjunction with the language file).
* Edit instance of the instance manager has been made wider.
* Meter Linkage now tries to work out the working directory for the file passed.
* Added %dl, %dr and %dm for double clicks to be returned by plugins and scripts.
* Added a new return value for the tooltips, %vl. This is replaced by the %tt value if present returned by script/plugin.
* Alerts can now have Custom Text returned.
* Added option to trim alert value before doing the alert compare processing.
* Added Mouse Up / Mouse Down for Left, Right and Middle mouse buttons (none of these actions work for Right in the taskbar).
* Meter Linkage will now work on Mouse Over/Out and Mouse Enter/Leave..
* Graphical images and Image Output Types now support http:// downloading. Animated Gifs not allowed at present.
* Removed the Text File size limit of 8k.
* Taskbar will now honour the commandline parameters to use call as client.exe taskbar <standard commandlines>.
* Grid and Highlight colours can be changed in the config editor.
* If ToolTip Text is over 999 then the text is truncated.
* Input Plugins can now force an update for the meter that they are associated with.
* Add alert values If Value has increased, and if value has decreased.
* Added keyboard input for input plugins.
* All Standard Meters are allowed a background color with an alpha blend.
* All Standard Meters are allowed a border.
* Rectangle has border width (if useful will add to other rectangle object).
* Mouse Drag Input option has been added
* Improved selection of the Inputs in the Config Editor
* Improved Copy and Paste code so that you can copy and paste across multiple instances of the config editor.
* All Standard Meters can draw a grid
* MeterList distiguishs between Meters and Graphic Objects
* Saved Config added to latest used list
* Mouse Wheel Up / Mouse Wheel Down have been added
* Maintain Aspect ratio has been added to Graphical Images
* Encryption has been added to proxy password
* Variable Number of Recent Configs
* Meter Names are now unique, using the group as part of the name
* Sorting of the Config Menu in all Clients (Optional)
New Features:
* Meter Maths.
* Remote Meter to monitor the new samurize server (rather than just xml and png, it will allow you to get information straight into samurize).
Download
Source -
Neowin
