Old 29-09-2004, 05:47 PM   #1 (permalink)
Default help needed
dis is gonna sound a real shocker to u
i m doin mech. engg. but i m really into computers.
so fellas can u tell me wat else i need to know besides c/cpp to get a good software naukri.
plz suggests some books for the above
atinsood is offline
Old 29-09-2004, 06:45 PM   #2 (permalink)
just do tally and it is sure that you will get a service
AMD Athlon64 3500+,Asus A8N Sli Premium motherboard,2 Gb 400mhz Ram,400 Gb Seagate Sata HD,XFX 6800 GT 256 MB GPU,Sony DVD drive & writer.
anubhavsinha11 is offline
Old 29-09-2004, 07:26 PM   #3 (permalink)
I dont think been a mech engg ya wanna be just a computer operator
or acountant. So fget tally.
N im not at all shoked.
I know an instrumentation engg. who earns 40k.
A B Com working for silverline n earning more than 90K.
N there are many more.
amitsaudy is offline
Old 29-09-2004, 07:43 PM   #4 (permalink)
Learn basics of hardware and networking. U can easily get a 15K job.
rakesh_1024 is offline
Old 30-09-2004, 11:25 PM   #5 (permalink)
what about HTML+JS+ASP+ASP.NET+C#+VB.NET
or
JAVA+EJB+JSP+WSAD(tool) or J2EE
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 01-10-2004, 12:38 AM   #6 (permalink)
try learning mech engg and related cad cam excell in your own field dont fall for the grass is greener on the other side concept
**** happens
pradeep_chauhan is offline
Old 01-10-2004, 11:41 AM   #7 (permalink)
club_pranay's Avatar
I suggest, u keep to mech only.....
it's got a lot of scope in future, keep working hard. try mastering in CAD CAM PRO-E. and u'll be on top of the world....
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 01-10-2004, 03:07 PM   #8 (permalink)
Networking-Lan,Wifi etc.
Unix
Concentrate on prgramming languages for the web-Jawa,C# etc
DBMS
Scripting lanuages
ETC
Old 01-10-2004, 09:45 PM   #9 (permalink)
alib_i's Avatar
Default Re: help needed
whoa
there is a lot u can do in computers while still being a mech engg
1. CAD/CAM - Computer Aided Designing/Machining - Lots of applications are developed for designing and manufacturing products of complex profile
2. Computational Fluid Mechanics - The most happening thing in thermal aspect of mechanical engg. Scope of GRE Apps too increases many folds in this field
3.Simulation - softwares like "Symbols 2000" ( http://www.symbols2000.com/ ) are used to simulate physical systems in a computer using various models and then the simulations are subjected to various loads to see the effect of loads on the system. All this happens on the computer without harming the real physical system. There are so many other simulation softwares.
Companies like GE, Thermax, Cummins, Transoft, etc want us mechanical engineers.
If you wanted simply to write programs or codes.
You can do so in the fields i've pointed out above, simultaneously using your knowledge in mechanical engg
There are thousands of ppl who can write programs in a software company
But few ppl have the technical knowledge along with computer soundness as these companies want it...
There are very good job oppurtunities in mechanical engg in relation to computer oriented white collar jobs
BTW, I'm a mech engg too
-Metallica
alib_i is offline
Old 02-10-2004, 11:36 PM   #10 (permalink)
sujithtom's Avatar
C/cpp are the best languages but to get jobs thay ask for PLs like java, some scripting languge and a web language, usually PHP or XML besides C and CPP
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 04-10-2004, 11:55 PM   #11 (permalink)
why don't u try AutoCAD+ MEch. Desktop heard hese r in market now nd rocking
