Old 25-09-2005, 10:07 PM   #1 (permalink)
cybermanas
Posts: n/a
Default Automatically stop services
Is there any software by which i can automatically stop any services i don't require
Old 26-09-2005, 04:49 AM   #2 (permalink)
Fresh Stock Since 2005
Default Re: Automatically stop services
What do you mean?? How would any program know what you would require......... Just type in services.msc in run window and stop or disable the services you don't require....
http://www.khattam.info
khattam_ is offline
Old 26-09-2005, 06:41 AM   #3 (permalink)
expertno.1's Avatar
Go to this website
it will tell you which service you have to keep and which dont
http://www.blackviper.com/WinXP/servicecfg.htm
http://www.beemerworld.com/tips/servicesxp.htm
then go to services.msc and sisable which you want from there
Thanks
Regards..
Expertno.1
expertno.1 is offline
Old 26-09-2005, 08:41 AM   #4 (permalink)
cybermanas
Posts: n/a
Thank you for the quick reply.
