Old 25-09-2005, 06:32 PM   #1 (permalink)
lahratla's Avatar
Default Backing up Avast Updates
I'm using Avast Home Editin 4.6 antivirus in WinXP+SP2. How do I backup the updates I have downloaded from its integrated internet update?
lahratla is offline
Old 25-09-2005, 07:32 PM   #2 (permalink)
i searched net but i cudnt find the sol, but anyways they are so small in size, i dont mind, dl them again and again
http://www.google.co.in/search?hs=8j...G=Search&meta=
Shwetanshu Srivastava
shwetanshu is offline
Old 25-09-2005, 08:55 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Well I am writing a guide called
"Backup Updates and Settings of your Softwares" which will include all famous softwares. I am hoping to complete it by September end. Will release it first on Digit Forum.
Well I have checked and found that all Avast! updates are in folder C:\Program Files\Alwil Software\Avast4\Setup Backup this complete folder.
Last Updated: 9:14PM IST
navjotjsingh is offline
Old 26-09-2005, 07:16 AM   #4 (permalink)
vignesh's Avatar
Thanks mate...
vignesh is offline
Old 27-09-2005, 06:38 AM   #5 (permalink)
expertno.1's Avatar
Also there is no need to use Avasts own update program
better to get the .exe file of the update from
www.avast.com
it will probably be this
http://files.avast.com/iavs4pro/vpsupd.exe
Thanks
Regards..
Expertno.1
expertno.1 is offline
