I am bcoz in win 98 nowadays many of the setup files is not working.whenever i execute them a box appears bearing 'Unhandled exception' and some error number and describing that 'Incompatible version of the RPC stub'.Plz help me solve this and make me
Gee thankx yaar
The WaNNaB GeeK iNHOUSe
My friend had the same problem. But in his case, the cd icon used disaapear if a cd wid scratches was used.
It turrned out da prob was in the hardware and it was solved once he got it repaired.
Whether You Think You CAN, OR Whether You Think You CAN NOT .... You are RIGHT.
Ohho .. Rocky ... you should have searched this forum for earlier posts .. anyway.. I post again ..
That Incompatible Version of RPC Stub error is due to InstallSheild's messup of systom files .. anyways .. here is the cure :
I recommend u to download Msrepair.exe even if u have Office 2000 on ur system ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
gee! thanks guys!
I was facing the same problem too!
A flea and a fly in a flue, were caught, so what could they do? Said the fly, \"let us flee!\" \"Let us fly!\" said the flea. So they flew through a flaw in the flue.
