Old 25-09-2005, 12:38 AM   #1 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default No Sound in DVD movie files using WMP 10 !!!
Guys!
I hv Samsung DVD drive and copied some DVDs on my comp.
I hv installed k-lite codec pack.
And also hv enabled DV support in WMP 10.
Whenever i try to play those files in WMP 10, it plays the video but no sound comes.
But when I plsy same files in Media Player Classic (which installed with k-lite codec pack) it plays them perfectly with sound without ne problem.
What can be the problem with WMP 10?
Recently i had WMP 9 , it also giving same problem, I installed WMP 10 but no benefit.
Is there ne solution?
PS: Pls don't suggest to install DVD player s/w, i don't want to install ne other s/w. And why should I install if Media player classic can play why not WMP 10?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 25-09-2005, 05:22 AM   #2 (permalink)
Learner
Kniwor's Avatar
I guess if u're online and u have not blocked WMP's internet acess in ur firewall, it should automatically download codecs to play that audio.
Kniwor is offline
Old 25-09-2005, 06:27 AM   #3 (permalink)
q3_abhi's Avatar
This happens with me too. All codec are installed n still nothing happens. Anybody help.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 25-09-2005, 01:03 PM   #4 (permalink)
Microsoft MVP
I hv WMP 10 and hv enabled Automatic updates and automatic plug-in d/l options too.
But still it shows only video not audio.
And when i try to play it using Real Player 10.5, it says that no DVD player installed and I hv to install one.
Is there ne solution for it?
Old 26-09-2005, 12:58 PM   #5 (permalink)
Microsoft MVP
Helloooooooooo!
Yohoooooooooooo...
nebody is there?
What happened guys!
No suggestions, No solution!!!
Pls give ur valuable suggestions here.
Waiting...
Old 26-09-2005, 02:17 PM   #6 (permalink)
Laptoping
Sourabh's Avatar
I have never faced such a problem but as of now I use Ace media codecs with Media Player Classic and everything plays in it and WMP too without any problems. To get through the problem in WMP 9/10 try installing Nimo Codec Pack and selecting FULL install during the setup.
Sourabh is offline
Old 26-09-2005, 03:21 PM   #7 (permalink)
Microsoft MVP
thnx dude!
I'll surely try it...
Old 26-09-2005, 04:21 PM   #8 (permalink)
expertno.1's Avatar
I hate Nimo codec pack
whenever i install this pack i am unable to play .mp3 files in WMP
when i unistall nimo codec pack the mp3 files play again
Dont know what goes
can anyone give me da explanation
Thanks
Regards..
Expertno.1
expertno.1 is offline
Old 26-09-2005, 10:06 PM   #9 (permalink)
Microsoft MVP
If I don't install the whole codec pack.
Is there ne specific codec, which can solve my problem?
I mean ne specific codec and its URl, from which I d/l that small codec and install it and then WMP 10 also starts playing DVD movie files properly with sound...
Old 27-09-2005, 06:24 AM   #10 (permalink)
expertno.1's Avatar
So its the time to hit and try
i dont think there is any specific codec
Try the different codec packs
anyone will surely do it
here see
http://www.thinkdigit.com/forum/view...119593f0d09a99
Thanks
Regards..
Expertno.1
Old 27-09-2005, 01:15 PM   #11 (permalink)
Another Brick in the Wall
drgrudge's Avatar
@Vishal Gupta,
There is a sticky that I started, did ya see that?
http://www.thinkdigit.com/forum/viewtopic.php?t=29004
Unistall the codec packs and install the ffdshow. It will play fine.
Or in case you want only a codec pack to be installed, then install XP codec pack and install the DVD codecs only and your file will play fine.
drgrudge is offline
Old 27-09-2005, 02:08 PM   #12 (permalink)
Microsoft MVP
thnx
I'll try it...
