Originally Posted by Ringwraith
Originally Posted by Kniwor
Originally Posted by quad master
The only difference between FX and NonFX is the unlocked multipler for overclocking on the FX series.
I strongly object u here, this is not the case.
then wat is the case?
If u are lucky enough to get a Sandeigo ....there's absolutely no difference with the fx procs!
SD 3700 = FX51
SD 4000 = FX53 but with locked upward multiplier
The comparision isn't done good enough, because you're comparing a Rev. E Processor with all its upgrades against an ancient Athlon 64 FX-51, that besides, uses Socket 940 (You take a little of a performance hit because you must use Buffered Memory Modules that are slower, though that is noticeable in Benchmrks and shouldn't have impact on real life). The most accurate comparision should be bewthem an Athlon 64 4000+ (Clawhammer) and a Socket 939 Athlon 64 FX-53 (Clawhammer too), where the diference is only the Unlocked Multiplier. But this was not the scene earlier and FX were justified, i dont know why still they are charging that much.
