dude...First things First !!!!
In Order to run Pages ending with ASP(abcd.asp) , you first need to either have PWS or IIS .PWS is found in Windows 95/98/Me. By Default it doesnt Get Installed (unless , you install using Custom way)....
IIS is installed in Windows 2000/XP/NT....bydefault it is installed
When you have done that , you should get a Folder called InetPubs in your System Drive , incase its C , then the path woould be C:\InetPubs
and wihtin this, there would be lots of folder (guess 6 or 7) , you should find one called wwwroot. This is where you will place all your files . all files including your html , asp pages everything which you want host .
One way of checking whether IIS Server is on or not is like this:
Type The Following address in your Broswer Address
Incase , some pages appear, then its enabled(by default , it is started). Incase , it is not, you can click on PWS Icon (think , it would be in Control Panel) and click on Start Button.
And in Xp/2000/NT , you can click on IIS Server in Admin Tools and Just Click the Play Button , it will start .
Try Following Code in a Note pad and save it as .asp page (like test.asp) and save it on the wwwroot Folder
Response.Write("Hello, Test Page")
and wooo..Ur ASP Pages are running.
You can Embed ASP Script within your HTML Page , but remember the <% %> tags.........
Good Luck
