Old 24-09-2005, 12:24 AM   #1 (permalink)
lahratla's Avatar
Default Rattling sound of FDD
I recently bought a PC with the following configuration:
1. Athlon 64 3000+ (939) CPU
2. 256x2 400MHz DDR RAM
3. 80 GB SATA HDD
4. MSI-RS480 (IGP) Mobo
5. Combo and FDD
6. 17" Flat CRT
7. WinXP+SP2
Earlier, I hadn't heard the loud rattling sound given out by the FDD on Windows logon. But now this rattling sound can be heard on Windows startup despite taking the following measures:
1. Disabling Floppy Seek in the BIOS.
2. Unchecking Restore previous folder windows at logon in Folder Options's View tab and
3. Gving a value of 91 for NoDriveTypeAutoRun in the Registry editor.
What do I do now?
lahratla is offline
Old 26-09-2005, 12:22 AM   #2 (permalink)
disable the floppy disk controller from the device manager , this might help you
thadhanihemant is offline
Old 26-09-2005, 01:02 AM   #3 (permalink)
well well well!!!! thats not a problem.. there are certain fdds that make the noise.. i had the problem also.. it was a p3 500 Mhz about 5 yrs back.. the floppy used to make that noise and it even makes today,, though i dont use that machine much) but the floppy is working fine.. all i can say is that try changing the fdd if u dont want the sound.. if that doesnot solve then there may be some other problem... like searching for a floppy during log on and as it dosnot find any floppy it makes a round--- but that is secondary
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
KnightRider is offline
