Old 24-09-2005, 12:08 AM   #1 (permalink)
lahratla's Avatar
Default Couldn't update Spybot S&D 1.3
I'm using WinXP+SP2. While trying to update Spybot Search & Destroy 1.3 by a dial-up connection, I can't update the Definition rules and Startup info. A "Bad Checksum" message appears in the info column and changing the server does not help. Please help.
lahratla is offline
Old 24-09-2005, 07:02 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
hmm there is an updated version of spybot ready for download... get that one... then try to update...
http://spybot.info/en/index.html
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 24-09-2005, 07:36 AM   #3 (permalink)
Reinstall and then try.ur firewall may block outpost connection for it.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 24-09-2005, 09:31 AM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Well jus try updating the S&D 1.3 after sumtime ,U dont need to reinstall it..coz sumtimes wen the server is busy then u get the msg "BAD CHECKSUM" otherwise there is no problem with ur S&D 1.3 as i also face the same problems even thou i hv a BROADBAND Connection....
IF u hv already allowed to "PERMIT" the S&D wen ur Firewall asked it then u need not do it again... Its jus that the servers are busy bro.. ! jus try sum other time..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 24-09-2005, 10:49 PM   #5 (permalink)
lahratla's Avatar
Thanks all of you for your replies.
lahratla is offline
