Old 23-09-2005, 09:04 PM   #1 (permalink)
Default help me.
when i have tryed to install grub by giving:
chroot /mnt/sysimage
grub-install/dev/hda
on using the first command no problem accuire's.But when i use
the second it say's "Not found or not a block device".help me to solve
the problem.
rajas700 is offline
Old 23-09-2005, 11:05 PM   #2 (permalink)
tuxfan's Avatar
YOu need to leave a space between the words "grub-install" and "/dev/hda"
tuxfan is offline
Old 24-09-2005, 05:21 AM   #3 (permalink)
After giving space also it say's the same thing.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 24-09-2005, 10:38 AM   #4 (permalink)
desertwind's Avatar
are you sure that your device is hda ? use the following command and post the output here
$fdisk -l
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
