Old 23-09-2005, 08:58 PM   #1 (permalink)
Ishan's Avatar
Default OS Uninstalling problem
Hey I described my problem before also, but didn’t got the solution
I am having Windows Xp in D drive , Windows 98 in C Drive and SUSE Linux has automatically made its partition somewhere on my hard disk, when I installed it.
Now Firstly I installed Win 98, then Win Xp and lastly SUSE Linux.
1) When I start my PC, firstly I get the option of Operating system Menu for Linux and Windows, on clicking Windows I get the option of XP and 98.
Can get them both with that of Linux option? How? Plz describe the Procedure.
2) How to uninstall Windows 98 if one does not have its option in the Add and remove program lists in Win Xp?
3) How to Uninstall Win Xp from Win 98?
4) How to uninstall SUSE Linux from Xp or Win 98?
Note: Once I got reply that SUSE Linux can be uninstalled by inserting its CD. Rebooting the computer and modifying the boot priorities for CD drive to boot first and then again restarting, the CD will run and an option to uninstall SUSE Linux will come.
I tried the same but due to that multi operating system Menu for Linux, I am not able to run the CD and directly the menu comes. So what should I do?
Please help……I’ll be very thankful.
You can reply here or can send me mail at:
toishanfromsomeonespecial@yahoo.com
Ishan is offline
Old 23-09-2005, 09:20 PM   #2 (permalink)
__Virus__'s Avatar
everything u asked is impossible...and explain this
__Virus__ is offline
Old 23-09-2005, 09:41 PM   #3 (permalink)
he i got the solutions for your problems
1. the OS menu ->the default boot loader in linux is grub(the best) now when
it is loaded i contains refernces to your partition table (where is the linux ext3 partition and where is the windows partition) .so the menu you have is the only menu you can get
2. uninstall win98 keeping winxp ->open win Xp .Go to Start ->Run and type c:\boot.ini
it will be like
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Micro soft Windows XP Professional" /fastdetect
C:\="Microsoft Windows"
make it like this
[boot loader]
timeout=1
[operating systems]
and delete the windows folder containg win98 and its programing files
doing this will direct you from Grub->winXp
Tell me if you like it i will tell the 3rd question afterwards
CHILL OUT AND HAVE FUN
popper1987 is offline
Old 23-09-2005, 09:51 PM   #4 (permalink)
Ishan's Avatar
For Poppers Hey Thank u very much .But as popper suggested .it will just dele the windows folder and by putting it to 1 second the difference will be just i'll not have time to choose th 98 option and the default will be Xp.......I understood what u wanted to tell......But isn't there any setup option for that...............I'll be waiting for ur other replies.
For Virus
I meant that can i have all the three oS lists to gather at the same time?[/u]
Ishan is offline
Old 23-09-2005, 09:59 PM   #5 (permalink)
ok now listen carefully go to dos prompt(during the startup) and type smartdrv
when it is loaded type uninstall.exe and win98 will be uninstalled
i will give you others replies tommorow (sorry for inconvenience-short of time)
Old 23-09-2005, 10:08 PM   #6 (permalink)
Ishan's Avatar
But I should type it in 98 or in Xp
Ishan is offline
Old 23-09-2005, 10:34 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Remove its entry from Boot.ini file as popper1987 suggested and delete "Program Files", "Windows", My Documents" folders from C:\ Drive - Its the right way to uninstall win 98.
First make windows 98 entry as default in Boot.ibi file then restart ur system and boot using win 98 Setup CD and type command "sys c:", then reboot. Now u can safely delete "Program Files", "Windows", "Documents and Settings" folders from ur D:\ drive.
Boot using windows 98 Setup CD and type command "fdisk /mbr" and reboot ur system, the linux boot loader will be gone, now u can safely delete linux partitions windows xp.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 23-09-2005, 10:36 PM   #8 (permalink)
U can't uninstall windows unless u upgrade.i think.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 24-09-2005, 11:32 PM   #9 (permalink)
Ishan's Avatar
Default Thanks..
Hey This gave me very good results...... I am very thankfull to all of you....But If u know more plz send ......
So it means I can't run CD during start up if Linux is installed?
Ishan is offline
