well u can use objectbar ... u can create a bar to replace ur taskbar and keep a custom start button
apart from this there was this oldd software called painkiller ...
search for it .. its a replacement for start menu .. adn pretty good
u can even change the icon ...
or u can use a visual theme in xp ... with the button u want .. but im sure u dun want to change ur whole appearance
then there was this software stylebulder from tgtsoft
same ppl who gave us style xp
u can edit the buttons etc .. basically the visual style ... but i dunno if u can change the name of the start menu from there .. im pretty sure u can ... so try that out first
No Mercy, No Limits.
