Today i performed non destructive recovery(only OS is re-installed) on my system today. I cud not afford to format syystem coz i had very important data on my Windows Drive. After i restarted, i cud not install Alcohol 120%, the error said: Error 25002. aSome driver has invalid name or onflict with other file or service in system. Pls choose other driver names or make sure u have rebooted after removal of software usning same names.
Also i had made all my account files private, so now i m not able to access my files, coz my username was deleted but my files are still there, but i m not able to access them, pls help guyz. I already tried Clear Read Only Attributes(CROA) software, but it didnt help.
Also now wen i connect my MTNL triband router (D-LINK), it shows the same icon in the tray which is displayed wen we connect pen drive to the system with the option: "SAFELY REMOVE HARDWARE". It never showed up before.
I m using Winodws XP with SP2, with most of the recent updates, Avast 4 Pro Anti-virus and ZAP 6. Pls help guyz.
