Unless you bypass the proxy, which has the MIME filters, you cannot download any of those blocked files. The filters check the extension of the file type, which you are trying to access. Sometimes, these filters stop working due to network problem or due to too many requests at that particular instance, so you can download those files. From your end you cannot do anything to bypass them, other than using some other proxy, which does not have those filters.
Souvik Sinha
