Old 22-09-2005, 11:37 PM   #1 (permalink)
muralikrishnan's Avatar
Default I Got An Error Message,Is't OS Problem or Any thing.........
Hi Friends,
I have Internet DIal- Up connection,When i have Disconnect My System From Internet I got an Error Message Like This
"A Fatal Exception OE Has Occured at 0167:BDD86EBD.The Current Application Will be Terminated.
* Press Any Key To Terminate the Current Application.
* Press CTRL + ALT + DEL Again Restart YOur Computer.You Will Lose
any Unsaved information in all Applications.
Press Any Key To Continue
(Note:A Fatal Exception OE Has Occured at 0167:BDD86EBD This Message Some Times Vary It Will Comes OD,OF Like That And The Values ALso Vary)
Some Body told the Os may be The Problem,I will ReInstall The OS First Few Days No Problem But After That It Again Continue The Same Problem.
Some Body Says Go to the Microsoft Website They Will give The Solution For Error Message.
I try To Find But I cant Get it.
If Any Body Know Tell Me & Suggest Me.
If Any Hardwaree Book Site Avilable That Also Tell Me.
Muralikrishnan.B.R
Somewhere on this globe, every ten seconds,
there is a woman giving birth to a child. She
must be found and stopped. - Sam Levenson
muralikrishnan is offline
Old 23-09-2005, 05:01 AM   #2 (permalink)
i think it is either due to a problem with any one of ur drivers or a software that u are installing. or may be due to some spyware or virus.
Shwetanshu Srivastava
shwetanshu is offline
Old 24-09-2005, 02:42 AM   #3 (permalink)
Learner
Kniwor's Avatar
Not an expert but this is possible due to a buffer overflow, and someone can use it to attack ur system.
or it can be a ram problem on that memory location, If it's one time then it is likely the first case.
dont quote me on this one.
Kniwor is offline
Old 24-09-2005, 05:40 AM   #4 (permalink)
May be ur driver prolem.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 24-09-2005, 11:59 PM   #5 (permalink)
thunderbird.117
Posts: n/a
Memory Proble.Download memtest
