Old 22-09-2005, 07:35 PM   #1 (permalink)
Default hfs webserver hoax ??please help (URGENT)
hello i installed hfs webserver and gave it one of my friends on lan so set up a high speed connection ,he can download movies from my computer at speed of 500KKbps but i can only download at 45-50Kbps . i have checked his speed limit and all the configuration is set up like mine . please help me
i
CHILL OUT AND HAVE FUN
popper1987 is offline
Old 23-09-2005, 01:33 AM   #2 (permalink)
It happens sometimes on a LAN, maybe a faulty switch or just a bottleneck somewhere. Ask your cable operator to check it.
wORm is offline
Old 23-09-2005, 01:30 PM   #3 (permalink)
i tried, he has openend file sharing port ,does that create a problem
Old 23-09-2005, 04:39 PM   #4 (permalink)
You can use default port 80 or any other port you wish to use.
I don't think ports are the issue here, its a network configuration problem and no amount of tinkering with HFS will help get better speeds.
wORm is offline
