Old 22-09-2005, 05:18 PM   #1 (permalink)
Default CD drive problem
Hi all,
Recently i am facing one interesting problem , The problem is , CD drive automatically closes (often)if i leave it for some time and not vice versa . I checked with updated anti-virus and confirmed that this is not due to virus.
what might be the problem ?.
Thanks
m.parthiban is offline
Old 26-09-2005, 02:57 PM   #2 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
Is that a samsung drive ...? If yes then the BRAND might be a problem
mod-the-pc is offline
Old 26-09-2005, 03:09 PM   #3 (permalink)
club_pranay's Avatar
this happens quite often when the tray is faulty, i think there's notthing much you can do about it, get it serviced.
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 26-09-2005, 03:09 PM   #4 (permalink)
might be a prob in the motor, and even if it does close after sometime, aint it good??? Prevents from breaking the tray. my frnd broke his cdrom's tray.
Also try keeping a disc in the rom, and see if it closes then coz samsung drives(if u have one) tend to behave in such a way.
Shwetanshu Srivastava
shwetanshu is offline
Old 26-09-2005, 03:14 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Its a very common problem!
My one friend hv same problem with his LG CD Writer.
May be Lens cleaner help u...
http://www.AskVG.com/
Vishal Gupta is offline
Old 26-09-2005, 04:19 PM   #6 (permalink)
MVP in VC++
Hey it happens also with the ordinary LG CDROM Drive and CD Writer...I think it not a problem of CD ROM Drive....It is a normal feature...
cvvikram is offline
Old 26-09-2005, 05:43 PM   #7 (permalink)
Well I had a similar problem but the opp. thing happened i.e. the tray came out automatically!!
Neway I threw that drive away but u can try takin it to the service center!!! But that dosent help much cause soon u r gonna get the prob again!
Aviation (Aircraft Maintenance Engineering)
http://www.ame-world.frih.net
Sankalp is offline
Old 26-09-2005, 10:07 PM   #8 (permalink)
Microsoft MVP
Kissi ko bahar aane ki jaldi hai.
Kissi ko ander jaane ki jaldi hai...
Try to clean the lens using Lens cleaner.
May be it help u...
