Old 28-09-2004, 08:58 PM   #1 (permalink)
Default pc repeatedly hanging
hi
i have a problem wid my pc. when i use my pc it hangs at ne odd time . sometimes it works well for 4 hrs but then sometimes it conks off in 4 mins. there is no warning msg frm windows . the red light in my pc just goes off.
i had recently put another 64mb of sdram . can it be d cause of this
also i have tried reformatting
but d problem still persists
plz help!!!!!!!!!! :roll:
android is offline
Old 28-09-2004, 10:30 PM   #2 (permalink)
Check the other ram sticks details(fsb etc).
Maybe they dont match.
amitsaudy is offline
Old 28-09-2004, 11:54 PM   #3 (permalink)
Yeah , it could be one of the reasons, do check the techSpecs abut the ream u put , coz u need to have same speed for both the chips to work..
one more things, do check ur Processor Fan , incase it stops or malfunctions , then PC hangs
Zindagi Ek JUa..Kabhi..Jeet...Kabhi Haar.....
Byeeee
K.K
techie_it is offline
Old 29-09-2004, 12:29 PM   #4 (permalink)
What OS do you use?
If its the NT/2K/XP family then check the system log n memory dump.
Old 30-09-2004, 12:22 AM   #5 (permalink)
from the bios disable quick boot. this double checks your ram. with faulty ram booting is a problem but if it boots then the ram shoudn't cause problems
gaurav
Regards,
Gaurav
gaurav_018 is offline
Old 01-10-2004, 06:15 PM   #6 (permalink)
If nothing works disassemble yr system and again
assemble it from sratch.
Maybe if ur lucky n some loose connection is .....
Old 01-10-2004, 06:54 PM   #7 (permalink)
lavan_joy's Avatar
If u post this in General section u can get more help...
this is bazzar...
LAZINESS IS THE ENEMEY OF SUCCESS
lavan_joy is offline
Old 02-10-2004, 10:50 AM   #8 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
[qoute="lavan_joy"]this is bazzar... [/quote]
This ain't Bazaar, this is Hardware Discussion
Check ur power-supply too.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
