Old 21-09-2005, 06:30 PM   #1 (permalink)
godsownman's Avatar
Default C- Printing output
Hello,
Is there any way to directly print the output of a C program from TURBO C .
Thanks.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 21-09-2005, 06:41 PM   #2 (permalink)
what o/p are you talking about?? explain plz.
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 21-09-2005, 06:51 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
i think he is asking hard copy print out ...
I dunno a way, me too will find it useful...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-09-2005, 07:10 PM   #4 (permalink)
if asking about hard copy, wen ur output is displayed, press print screen key on ur keyboard and paste it in notepad, then u can take ur prnt out.
If u r asking about exe file, then it will be located in ur bin folder in TC by the name of ur program.
If u r asking how to see the output without going to Window--> output, put getch(); before the closing brace.
shwetanshu is offline
Old 21-09-2005, 10:23 PM   #5 (permalink)
godsownman's Avatar
Yes I mean when the program runs the black and white screen that appears , thats what I want to print.
@ shwetanshu,
Thanks for your solution.
I was aware of that , but I was doing it slightly differently. I was transfering it to paint.
Anyway your idea is better and its easier and faster also .
