Old 20-09-2005, 08:11 PM   #1 (permalink)
Default encrypting folder
I want to to know whether there is any way to encrypt the folder without using any software.
navino87 is offline
Old 20-09-2005, 08:38 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
if u have NTFS, u can do so...
Right clik on the fol/fil u wanna encryp and clik on Advanced > check the box "Encrypt contents to secure data" and voila ! ur done ,...
But i dunno how it can be reused on other comps i.e. i dunno how to assign private/public keys...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-09-2005, 05:30 PM   #3 (permalink)
Default meaning
what does encrypting folder means? is it that making a folder password protected ?
navino87 is offline
Old 21-09-2005, 05:34 PM   #4 (permalink)
i wanna password protect a folder without using any software
navino87 is offline
Old 21-09-2005, 05:36 PM   #5 (permalink)
Commander in Chief
yes, kinda... but it has a key instead of a password.
the comp that has the same key can open ur file...
i think its somethin like this...
try a wiki on it...
Harsh J
www.harshj.com
Old 21-09-2005, 05:42 PM   #6 (permalink)
how to do this?
I dont want any one to have a look at my datas in the same computer & with same user name.
navino87 is offline
Old 21-09-2005, 05:48 PM   #7 (permalink)
Commander in Chief
well, u asked for encrypting 1st and so was my answer...
Srry if it confused...
Well, u can use a zip tool (windows too has it) to password protect and compress ur folders...
I think this is a nessecity s/w all have so it shud be no problem...
Harsh J
www.harshj.com
