Old 20-09-2005, 07:43 PM   #1 (permalink)
Default burning trouble
heh i m new here,,, i ve got a problem burning my cds.. actually all the movies that i wanna burn are more than 700mb in size so i unable to burn using my nero sftware the sizes r lik 730mb,,720mb.. so can u guys offer me a free software to compress or cut the files.. i ve a demo version of vcd cutter but it lasts for only 7 sec..pls help
one mor what's the diff btwn intel centrino pentium m and just pentium m..
theres no centrino logo on my laptop... and it doesnt display in config also .. so i jus wanted to kno bout that..
if ne has ne software cud u pls send me ne ..i ve bought bout 12cds but its lyin here wit me..
dummy is offline
Old 21-09-2005, 12:00 AM   #2 (permalink)
psot in the QnA section
man are these sections tough for u people to understand that u post in the wrong sections ?
i mean each section ahs a description under it right ?
READ IT GOD DAMN IT
No Mercy, No Limits.
theraven is offline
Old 21-09-2005, 12:49 AM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
well, to burn big files u can either enable overburn or u can buy 800 mb cds.
For Intel centrino and pentium, check www.intel.com
p.s. > @raven - hes a new forummer, so plz dont damn him man !
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-09-2005, 06:36 AM   #4 (permalink)
expertno.1's Avatar
Hi dummy ,
Same thread here
http://www.thinkdigit.com/forum/view...l+dub+expertno
Anyways the solution
download virtual dub from here
http://www.virtualdub.org/
downlaod divx helium codec from here
http://labs.divx.com/archives/000055.html
install them
now in virtual dub
use the compressoin option
select the divx compresiion and edit the changes
make the video a little bit smaler or decrease the kbps sttream from there
or else
u could try anothr feature i.e
Overburning
How to overburn
http://www.tacktech.com/display.cfm?ttid=253
this will surely fit yours 707 mb in your 700 mb
Thanks
Regards..
Expertno.1
expertno.1 is offline
Old 21-09-2005, 08:12 AM   #5 (permalink)
q3_abhi's Avatar
You may buy a 800 MB CD. So there will be less chances of overburning o fail.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 21-09-2005, 12:09 PM   #6 (permalink)
if these are movies and their length is less than 80mins, u can make a video CD
shwetanshu is offline
