Is there any difference between writing a video file in slow speed(1x) and high speed (52x)
Yes there is the difference
While writing at 1x it will take you too much to write but there will be 99.99 % chance that the data will be successfully written
Moreover ,
the new technologies and the cd writers are now provided with buffers eihter of 2mb or 8 mb
so even at wrting at 52x there will be no problem
if ur writer is old then its better to use it at less than the max
such as if ur writers max is 48x then use it at 32x
this will mark the data on the disk more acurately
but as you know that time is precious
better to write at high speeds with
"buffer underrun protection"
as Nero and new writers no longer show any fault in writing at 52 x then u can write at 52x
I think ur doubts are clear
in summary ,
1x makes more stability but very less speed
52c makes less stability but extreme speeds
so i suggest you to go for a medium write i.e 32x
Thanks
Regards..
Expertno.1
