View Poll Results: Which is betta and future proof?
Amd64 3200+ 939 with Nforce4 motherboard 10 76.92%
Intel P4 LGA775 3.0(2mb L2 cache with 955 motherboard 3 23.08%
Voters: 13. You may not vote on this poll
Old 19-09-2005, 06:50 PM   #1 (permalink)
Default Which one???65-70k budget.
hello i am buying a new pc and my budget is 65-70k max so tell me the best i can get for this budget.P4 LGA775 3.0ghz 2mb L2 cache with 955 or 3200+ 939 with Nforce4 mobo?tell me whole config speakers,graphics,ram,monitor etc etc...with price.
b fast because with in 2-3 days i have to pay my vendor for the hardware.
thanx
diabolic_saint is offline
Old 19-09-2005, 07:01 PM   #2 (permalink)
gxsaurav
Posts: n/a
u got a lot of budget, y go for a 3000+
Go Athlon64 3500+ Venice core with Asus A8N-E motherboard
Old 19-09-2005, 07:02 PM   #3 (permalink)
Aniruddh's Avatar
well very hard to decide between the 2 but i'll go wid 3ghz 2MB L2 and 955mobo i guess wid gud gpu is a betta choice eva i m plannin to buy dat combination.by the way poll wil tellu the exact thin juz wait and c.
Aniruddh is offline
Old 19-09-2005, 07:08 PM   #4 (permalink)
@gxsaurav i am not going for 3000+ infact 3200+ and i guess that will be enough because there wont be much difference between the 2 so dont want to spend money on that instead can use that money on other things.
Old 19-09-2005, 07:49 PM   #5 (permalink)
depends on wat u want...u wanna game then get the amd...vid/audio encoding/3D get the intel
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
Old 19-09-2005, 08:14 PM   #6 (permalink)
both i will be playing games as well as vid/audio encoding/3D and all so which one now
Old 19-09-2005, 08:34 PM   #7 (permalink)
gxsaurav
Posts: n/a
in that case 3200+ venice e3 oe e6 core will be better then intel
same performance in gameing, with a difference of 5 to 10 seconds in video encoding, but a lot less temprature,
Old 19-09-2005, 08:36 PM   #8 (permalink)
Aniruddh's Avatar
intel if ur going for a 6600gt or above gpu then u shud opt for intel.but dun 4get to go for a well ventilated cabinet wid loads of fan as intel proc really heats up a lot.
Aniruddh is offline
Old 20-09-2005, 09:16 AM   #9 (permalink)
MVP in VC++
You better go for AMD still...
cvvikram is offline
Old 20-09-2005, 12:19 PM   #10 (permalink)
The Hardware Labs
mohit's Avatar
Umm go for INTEL ...get the following
Penium 4 630 (2 Mb L2 cache , 64 bit compatible)
Asus P5 WD2 Premium (955X Chipset)
512 or 1024 MB DDR2 667 Mhz (Kingston , Corsair)
Leadtek 128 Mb ddr3 6600GT Extreme PCI-E
Dont buy DDR2 Ram lower than 667 Mhz else it will be a bottleneck.
mohit is offline
Old 20-09-2005, 12:56 PM   #11 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Go for
Amd 3200+
Asus A8N-E or SLI
XFX 6600GT 128MB PCIe
1 GB DDR400 Ram of ur choice
buy 2 SATA HDDs so u can rig 'em up in RAID0 as nforce4 mobos support inbuilt RAID...(good for games with large level loading time like DOOM3)
Buy a Wireless keyboard/mouse set with an additional optical wired mouse(some games show lag while playing via wireless Input devices)
450Watt SMPS for non SLI and >500watts for SLI mobo
Buy a decent set of wireless/wired dolby headphones and insted of buying a expenseive speaker set rig up ur Home stereo system and with PC too good if u have one of those boombastic hifi mojo rising music systems...
Buy two monitors.. atleast 17" or one 19" and the other 15"(or 17") or but a 14" or 15" LCD with a 17" monitor and rig both of them up to ur graphic card so that u can make some really serious looking setup... and do some really serious work too(dude this is real multitasking) .....
This is very helpfull as u can do more than twice the stuff then u do on one screen man!! and a wirless keyboard/mouse will compliment this setup very nicely...
Get a decent TV-Tuner too (go for the media center kind .. really neat to control ur PC via remote, all that S#$% like music,movies,photos,TV etc.)
Alsi get a DVD-RW and a DVD-ROM to complete the rig...
NOW u can go on living a dream......
Rollercoaster is offline
Old 20-09-2005, 01:02 PM   #12 (permalink)
Actually this is what i am going to buy in a couple of weeks...
Wish me luck guys...
Old 20-09-2005, 06:38 PM   #13 (permalink)
Good luck RollerCoaster...Go for AMD...
ShAsTrI.
cybershastri is offline
Old 21-09-2005, 06:48 AM   #14 (permalink)
AMD 64 3200+, Asus A8N-E, 2*512Mb DDR PC3200, GIG 6600GT(Copper cooler , good heat disipation), 160GB/200GB SATA, Viewsonic E70f 17" monitor,etc..
divyadbzgt1 is offline
