Old 19-09-2005, 03:54 PM   #1 (permalink)
nishant_nms's Avatar
Default Flashing the BIOS
I have an AMD Athlon 64 2800+ processor, GIGABYTE GA-K8VM88M (Rev 1.0) motherboard, 256 MB DDR 400, Samsung 5400 rpm 40 GB HDD, Samsung Combo SM-352F and a 200 Watt SMPS. It has got VIA K8M800 chipset and a S3 onboard graphics namely UniChrome Pro(2). My problem is that sometimes when the resolution changes the monitor goes blank it behaves as if it is not getting any signal the LED on the monitor turns into orange from green. This happens while starting a game or changing the resolution or the colour depth. The display comes back to normal when I restart the system or after sending the system to standby then again starting it. It also turns to normal sometimes when the resolution is restored to the normal (earlier resolution). The problem does not occur all of the times. My motherboard’s current BIOS version is F3 and the new BIOS version available is F8. I want to know that flashing my BIOS will solve the problem or I need to contact the service center or it is due to the SMPS (My monitors power supply does not goes from the SMPS). I am using the latest drivers for my both OS. This problem occurs in by both OS Windows XP Professional and Windows XP x64 Edition.
nishant_nms is offline
Old 19-09-2005, 10:11 PM   #2 (permalink)
I do not think you have 200 watts power supply... It should be around 300 and above...
For flashing the Mobo use the following Link:
1. Link
Regards
shivaranjan.b is offline
Old 19-09-2005, 10:37 PM   #3 (permalink)
I am sure about my SMPS and i had got the BIOS update file i want to know will it solve my problem or not
Old 19-09-2005, 10:55 PM   #4 (permalink)
__Virus__'s Avatar
b sure first after you diagnostics that u need to flash ur bios...cos wrong flashing may render ur mobo useless..and there is no system restore....
__Virus__ is offline
Old 19-09-2005, 11:17 PM   #5 (permalink)
Hey How can i be sure at the GIGABYTE site they do not give information about the fixes in the new updates they just show the new version
Old 20-09-2005, 12:11 PM   #6 (permalink)
what crap is going on here ?
ur monitor goes blank cuz the onboard adapter doesnt support those refresh rates/color depth/resolution
u have to keep those setting within limits of the video card
upgrading ur BIOS is not gonna do jack **** for u !
infact when ur changing the resolution thru display properties and it goes blank .. wait 15 seconds .. it'll get back to normal
for these 15 seconds dont press any key .
ur old res will be back
everytime u change the resolution windows asks for confirmation before makin it final ..
it waits 15sec. for confirmation otherwise it reverts to old settings
so if by mistake u press enter or space, it'll select "yes" and finalise ur settings
this however is not the case for when u start games
when u start a game and it goes blank press alt+tab till u can see ur windows again
now goto to task manager ( ctrl+alt+del) and end the game window and/or process
and u wont have to restart
thats all i can do to help u
No Mercy, No Limits.
theraven is offline
Old 21-09-2005, 11:45 AM   #7 (permalink)
Default No problem with refresh rate
I am sure that i am witin the possible resolution and refresh rates. And the ways mentioned to get the display back works only a few time u should have read my post correctly
Old 21-09-2005, 04:17 PM   #8 (permalink)
like i siad if u press anything it might not come on ..
what is the resolution ur tryin to acheive and at what bit rate and frequency ?
its an onboard sis card ..
what are the limits that u think it has ?
cuz its not higher than 1024*768 @16bit @60hz im sure
theraven is offline
Old 24-09-2005, 11:39 PM   #9 (permalink)
Hey I told that i can sometimes change my resolution and sometimes not on the same settings
Old 25-09-2005, 06:24 AM   #10 (permalink)
q3_abhi's Avatar
Update BIOS with simple n easy steps here:
http://www.thinkdigit.com/forum/view...ating+solution
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 25-09-2005, 01:32 PM   #11 (permalink)
I am facing this promblem when i decrease the resolution too.
I wanted to know that the promblem I am facing could be due to 200 Watt SMPS or not.
Old 25-09-2005, 02:33 PM   #12 (permalink)
nope its not because of ur PSU
theraven is offline
