Old 19-09-2005, 08:26 AM   #1 (permalink)
Default ADRPAN.EXE
i m Using windows XP home Edition.
when i press alt + ctrl + del
i see a file name adrpan.exe.....
can anyone tell me plz what is that and how can i remove it
i tried to remove it with spyware doctor... but i came again
and it is residing in windows\system32 folder
please help
inderdhiman is offline
Old 19-09-2005, 09:49 AM   #2 (permalink)
Thread moved here from Latest News. Please post in the correct section in order to get prompt replies.
Nemesis is offline
Old 19-09-2005, 12:08 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Did spyware doctor detect it as a spyware?
if YES, then check that whether it has an entry in System Startup, by going:
Start -> Run and type msconfig, then goto Startup tab and check its entry.
If it exists then uncheck it and restart in Safe Mode and delete the file from system32 folder.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 19-09-2005, 07:50 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
adrpan.exe...i searched for it on google, msn and yahoo. came up with nothing.
can only suggest you remove it from ur start-ups. either thru winxp/sp2 utility or use ccleaner (www.ccleaner.com). also use ccleaner to clean ur pc junk.
then scan you pc with anti-virus (avast or avg) and anti-spy (your spydoc AND adaware or ms anti-spy). if u can also download and use ewido, great !
if u can, do post ur hijackthis log here.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 19-09-2005, 08:34 PM   #5 (permalink)
Post your Hijack this log then it will be more helpful in analysing the problem..
shivaranjan.b is offline
