Old 18-09-2005, 11:50 PM   #1 (permalink)
rajat22's Avatar
Default AutoPatcher XP September 2005 Full/Lite Released
AutoPatcher XP is an installation package designed for you Windows XP so you can update your system quick and easily. The AutoPatcher XP features a slick looking GUI and and can be customized to install as much or as little as you please.It is especially useful after a fresh instal of your Windows XP. Just simply run this Application, and it will get your machine up to date in a matter of minutes so you can enjoy the better things in life instead of sitting afront of your computer and trying to figure out which update is right for you. The stability and the usability of this program is also excellent. Thanks to its slick GUI and its easy to use interface, updating your machine is a snap! Simply pick the updates you want and the ones you don't want and click update. If you're running Windows XP, than this is a must have for any user!
Homepage - http://www.autopatcher.com/
Size of Full version - 161 MB
Size of Lite version - 100 MB
Download Full
http://download.softpedia.com/softwa...5_ENU_Full.exe
Mirror
http://download.softpedia.ro/softwar...5_ENU_Full.exe
Download Lite
http://www.agentoddstar.com/AutoPatc...5_ENU_Lite.exe
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 19-09-2005, 01:59 PM   #2 (permalink)
damn it
i just downloaded august a week back
No Mercy, No Limits.
theraven is offline
Old 19-09-2005, 04:21 PM   #3 (permalink)
expertno.1's Avatar
damn it
HEY man why do you download it ?
I always get it in the DIGIT DVD
so no need to worry
it will be in the next DIGIT DVD
Hurray ! Digit is gr8
anyways thanks for the link rajat
Thanks
Regards..
Expertno.1
expertno.1 is offline
Old 19-09-2005, 07:42 PM   #4 (permalink)
softpedia linx never work for me, i had to download it from: http://www.agentoddstar.com/AutoPatc...5_ENU_Full.exe
and expert i agree with u taht digit gives autopatcher, but by the time it arrives to us, another one is already out.
shwetanshu is offline
